The AC/heater fan works on the highest setting number 5. I have replaced the A/C heater control head with hopes of correcting the issue. No luck. I am guessing there is a relay/resistor that is bad being the fan works on high. Any advise on where to look and how to check once located? I have checked all fuses and everything test okay.
SPONSORED LINKS
Saturday, April 5th, 2008 AT 10:34 PM
KRUSZE2
MEMBER
Hi, to answer your question, the Blower Motor Resistor Module is located on the passenger side, under the dash, it is mounted in front of the blower motor. These are very common for going bad.
