1994 Plymouth Acclaim won't start
RVT6749
  • 1994 PLYMOUTH ACCLAIM
  • 4 CYL
  • FWD
  • 56,000 MILES
Car was working fine, parked it for two days, tried to start it, will crank, but won't start. Fuel pump is not getting voltage, checked with meter, disconnected gas line, no gas comes out when cranked. Found relay to fuel pump and hot wired it and fuel pump worked. So it is not the fuel pump. I replaced the relay and still did not work. I have changed the fuel filter.
Do you
have the same problem?
Tuesday, November 4th, 2008 AT 12:03 AM
JAMES W.
Do you have spark? A yes or no will a difference in which direction we go.
Tuesday, November 4th, 2008 AT 3:15 AM
RVT6749
Yes I do have spark, just no voltage going to fuel pump
Tuesday, November 4th, 2008 AT 2:52 PM
JAMES W.
You've done good! The fuel pump relay gets it's instruction to close from the computer. If you have, or have access to, a scan unit you can hook it up a see if the computer is telling the relay to close. Having sat for a couple of days shouldn't be a factor.
Tuesday, November 4th, 2008 AT 3:24 PM
Recommended Guides
