Oil pressure sending unit location?
BVFDFIREMANSLADY
  • 2016 CHEVROLET MALIBU
  • 61,768 MILES
Location of oil pressure sending unit?
Sunday, August 19th, 2018 AT 10:45 AM
  • 52,797 POSTS
Good afternoon.
You did not list the engine size so I attached a picture of both the 1.5 and the 2.0.
The switch is out in the open and is accessed from the bottom of the car looking up.
Sunday, August 19th, 2018 AT 1:19 PM
JEREMYBRANDSMA
  • 2013 CHEVROLET MALIBU
  • 2.5L
  • 4 CYL
  • 95,000 MILES
Where is the oil pressure sensor located?
Monday, September 7th, 2020 AT 2:07 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Got this from Alldata. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. The Medic
SAM60
  • 5 POSTS
  • 2.5L
  • 4 CYL
  • FWD
  • 39,000 MILES
I have an AC-Delco replacement but cannot where it is at. Had DTC P06DE. Oil level is fine and engine runs quietly and has no loss of power.
STEVE W.
  • 12,973 POSTS
The oil pressure sensor is item #2 tucked behind the intake on the rear of the engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ALDO CERVANTES GIL
  • 2010 CHEVROLET MALIBU
  • 2.0L
  • 4 CYL
  • 154,106 MILES
I look under the engine and I'm having difficulty on the location. I asked my buddy where could the location be at. Right above the oil drag plug I looked up ahead and it was close to the manifold is a tight spot. But if you can help I greatly appreciate it.
SCGRANTURISMO
  • 4,897 POSTS
I have included the information that you requested in the diagrams down below. It is located right in back of the oil filter. Please, if you have any other vehicle related questions, feel free to ask.
Thanks,
Alex
2CarPros
DONNA MCCARTHY
  • 2009 CHEVROLET MALIBU
  • 2.0L
  • 4 CYL
  • 80,000 MILES
Where is it located and what does it look like?
SCGRANTURISMO
  • 4,897 POSTS
I have included a diagram of your vehicle's engine and all of the switches and sensors on it. The Oil Pressure Switch(OPS) is number 11 on the diagram. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
GAR67
  • 2008 CHEVROLET MALIBU
  • 100,000 MILES
I have a leak that is coming from above the oil filter housing. I changed the oil pressure switch, but that did not help.
I am thinking about changing the oil filter. I am not sure that would help. Just going about the least expensive
way. The leak seems to be coming from the engine above the filter. Could this be valve cover gaskets.
My engine is v6 3.6l
need help
  • 52,797 POSTS
Possible but the pressure switch is more suspect
GAR67
Even though the oil pressure switch has been changed?
  • 52,797 POSTS
Make sure it is not leaking from there. It is common when installing that you can break the plastic top on installation/
STEPHANI JOHNSON MCDANIELS
  • 5 POSTS
  • 2.4L
  • 4 CYL
  • 190,000 MILES
I need to replace my oil pressure sensor and I can't find a diagram of the location. I am pretty sure I see it but want to be sure. My car listed above is the LT model.
GAR67
I will take it off and check it. It only leaks at cold start. Does this sound about right
  • 52,797 POSTS
Good afternoon,
The sensor is above the oil filter. I attached two pictures for you to view.
Removal Procedure
1. Remove the starter. Refer to Starter Motor Replacement (LZ4) Starter Motor Replacement (LAT) Starter Motor Replacement (LY7).
2. Disconnect the engine wiring harness electrical connector (2) from the oil pressure sensor.
ImageOpen In New TabZoom/Print
3. Remove the engine oil pressure sensor.
  • 5 POSTS
Is this the sensor?
  • 5 POSTS
The sensor that I need to replace is slightly below and to the left of the oil filter. I'm being told that is the oil pressure sensor but I need confirmation.
  • 52,797 POSTS
Do you have a new sensor? If you do, remove the connector from the sensor in the picture and make sure it fits on the new sensor. That will confirm it.
  • 5 POSTS
It's on it's way here now.
