Starter location
AMBERDURAN
  • 2003 ISUZU ASCENDER
  • 5.3L
  • V8
  • 4WD
  • 143,000 MILES
My car is not starting. All the lights come on bright and there is a clicking noise when I go to start it. I was told it is my starter but where is it located on my car?
Monday, October 16th, 2017 AT 11:49 PM
HARRY P
  • 2,292 POSTS
The starter is located under the truck, above a catalytic converter, and near the transmission. I have attached the removal procedure, captured from AllData. Installation is the reverse.
Tuesday, October 17th, 2017 AT 5:12 AM
HARRY P
  • 2,292 POSTS
It could be just a loose electrical connection. I would check the battery cables and make sure that they are both super tight and clean. Here is a general guide on doing that: https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked
To me it really sounds like your starter is wearing out. You can try jumping it. Even though the battery strength is good, this will give you a few extra amps and might get it to turn over. Or you can have someone tap the starter with a mallet or other blunt object while you turn the key. If either of these things work, then you will need to get a new starter installed.
Tuesday, October 17th, 2017 AT 3:36 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,262 POSTS
Here are a couple of guides to help you get the job done:
and
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Wednesday, October 18th, 2017 AT 12:23 PM
