Timing chain marks?
LILUN
  • 1997 NISSAN TRUCK
Four cylinder two wheel drive manual.
Just replaced the timing chain but not sure how to reset the timing to the proper specs. The timing looks to be set right. The truck still will not start could the distributor be 180 degrees out?
Do you
have the same problem?
Wednesday, May 26th, 2010 AT 7:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, the rotor could be positioned wrong. Crankshaft pulley marks and front cover marks should align and the distributor. Rotor should point to plug wire number one on the cap. Here are both the four and six cylinder timing marks for the camshaft. Below
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_539.jpg
Wednesday, May 26th, 2010 AT 9:00 PM
LILUN
The truck still is turning over really slow and there is a little tapping noise but when you move the distributor cap the noise stops. Could a bad distributor cause that?
Friday, May 28th, 2010 AT 9:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Crankshaft sensor may be at fault instead of the distributor.
Saturday, May 29th, 2010 AT 9:01 AM
LILUN
Will an engine out of a 1994 Nissan truck work in a 1997 Nissan truck?
Monday, June 7th, 2010 AT 11:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The 1990 to 1997 Nissan Hard-body truck used the same engine, the 2.4L SOHC twelve-valve.
Monday, June 7th, 2010 AT 7:07 PM
SAYLES4
  • 1997 NISSAN TRUCK
  • 145,000 MILES
Replaced timing chain and sprockets. Thought we aligned it correctly. Now it runs but timing is way advanced. Cannot adjust less then twenty degrees btdc. Was running good before we changed out the timing chain. We were trying to do preventative maintenance.
Saturday, April 1st, 2017 AT 4:47 PM (Merged)
  • 52,797 POSTS
Even though you had the marks set, they may have moved when you tension-ed the chain with the tension-er. Re-check the marks.
SAYLES4
Just verified that the marks are set and that they did not move. The truck seems to run good, but my timing is still at twenty btdc. Can I let it go like this?
  • 52,797 POSTS
Twenty is not too bad for idle timing. Going to check the spec.
  • 0 POST
  • 1997 NISSAN TRUCK
  • 14,000 MILES
I have just replaced the timing chain, both cam and crank gears, and rear oxygen sensor. Erased the check engine light, now no lights are on.
I had the number one piston up and I set it on TDC. The way the book shows me is the first marking is negative 5, 0, 5, 10, 15, 20.
I aligned it at the zero marking. Now when I start the truck it does not want to idle, have played around with the distributor, advancing and retarding the timing, cannot get it to idle.
When I give it some throttle it wants to run better, seems like it is flooding out. Can you help me? Thank you.
  • 52,797 POSTS
What code? What kind of truck? What engine?
LEEMIKESKA
  • 1997 NISSAN TRUCK
  • 4 CYL
  • MANUAL
  • 240,000 MILES
Four cylinder two wheel drive manual 240,000 miles.
I just bought this pickup and it runs great. I do not think the timing belt has ever been changed. Should I change it even if it runs like a dream?
  • 31,938 POSTS
Hi there,
Change the belt as a matter of coarse, if it fails and it will not give any warning you will at best be stranded and at worst do serious damage. I am not sure which engine you have so I do not know if it is interference or not, this goes for any belt driven engine. If you do not know the exact history replace the belt.
Mark (mhpautos)
SKOOTER1113
  • 1997 NISSAN TRUCK
  • 2.4L
  • 4 CYL
  • 4WD
  • MANUAL
  • 230,000 MILES
Had to take the timing chain out, it had broken the timing adjuster and rubbed a hole in the timing cover where the water jacket was, letting water in the oil. So it had already jumped time. So I changed everything and bought new parts. Need to know how to time it back. Your help would be greatly appreciated.
Sunday, September 9th, 2018 AT 4:51 PM (Merged)
HMAC300
  • 48,606 POSTS
Here are the camshaft timing marks. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
BERSYL671
  • 55 POSTS
  • 1994 NISSAN TRUCK
  • 4 CYL
  • MANUAL
Hello again, I just want to thank you for all your help and just another problem again. I am working on the truck listed above with a k24 motor. Now I am putting back the timing chain and I forgot the sequence on putting it back. May I have the timing marks and the oil pump marks for this vehicle? Thanks again.
Wednesday, July 29th, 2020 AT 1:36 PM (Merged)
Here is a guide and the diagrams below so you can see how the job is done:
https://www.2carpros.com/diagrams/nissan/pickup/1994
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
RGINSBERG
  • 1994 NISSAN TRUCK
  • 4 CYL
  • MANUAL
  • 220,000 MILES
How do I set the valve cam timing to TDC?
MERLIN2021
  • 17,250 POSTS
Is your timing chain still OK?
2CP-ARCHIVES
  • 4,544 POSTS
  • 1993 NISSAN TRUCK
  • 250,000 MILES
4cyl. Has fire and is getting gas, timing marks are lined up correctly
