Power windows not working
NAS0151
  • 2003 MERCURY MOUNTAINEER
Electrical problem
2003 Mercury Mountaineer 6 cyl All Wheel Drive Automatic
I have replaced the window lift motor and the window switch to the front passenger door. The window still does not go up and down. I tried them in the rear door and they work there. If the switch in the driver door was bad, would that cause the window motor not to work? What else to I need to check?
All windows work from master switch and I have not seen any exposed wires. I have not checked with a meter, just visual. I was wondering if master switch could be bad, or if there is a fuse or relay to check?
Sunday, August 15th, 2010 AT 8:30 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,081 POSTS
Yes the master switch is most likely bad becasue the entire systems power runs through the main control switch located at the drivers door. Here is a guide that will give you an idea on how to test it.
https://www.2carpros.com/articles/electric-window-repair
and
and
Here is how it will be to change the switch in your car and I will include the wiring diagrams so you can see how the system works. (below)
Cheers, Ken
Friday, November 10th, 2017 AT 3:42 PM
WEST201
  • 8 POSTS
  • 89,000 MILES
I replaced master switch drivers door, fuse under dash circuit breaker under hood
Friday, November 10th, 2017 AT 3:42 PM (Merged)
WEST201
  • 8 POSTS
I will donate a nice donation if solution works, previously been ripped off so skeptical sorry nothing personal
SATURNTECH9
  • 30,869 POSTS
Do you have a mulitimeter to do some testing?We need to trouble shoot this problem to find it.
WEST201
  • 8 POSTS
SATURNTECH9
  • 30,869 POSTS
Alright left side of engine compartment drivers side at the fender apron in the fuse box see if fuse number 6 60amp has power to both sides. Also behind the left side of the dash in the fuse box fuse number 17 15amp see if there is power to both sides of that fuse. Let me know what you find.
WEST201
  • 8 POSTS
Yes power to both
MARK MAKAREWICH
  • 10 POSTS
  • 2002 MERCURY MOUNTAINEER
  • 3.6L
  • V6
  • AWD
  • 180 MILES
Stopped working, checked sixty amp fuse under the hood checked the number seventeen underneath the steering wheel. I am not sure if it is the relay or not and or where it is.
SATURNTECH9
  • 30,869 POSTS
Ok behind the left side of the dash there will be a light blue wire with a black stripe coming out of thr fuse box it should have power with the key the run position.
CARADIODOC
  • 33,755 POSTS
All the windows are not working in both directions? If so, start by inspecting the wires between the driver's door hinges to see if any are frayed or broken.
Did they all stop working at the same time, or did anything noteworthy happen leading up to this?
WEST201
  • 8 POSTS
Yes it has power
MARK MAKAREWICH
  • 10 POSTS
Nothing out of the ordinary just stopped working.
SATURNTECH9
  • 30,869 POSTS
Now key in the run position go to the master window switch on the drivers door see if the light blue wire with a black stripe has power going into the switch?
MARK MAKAREWICH
  • 10 POSTS
I have looked at the sixty amp fuse under the hood it is okay I believe the thirty amp relay under the hood is also working properly I am getting power to the fifteen amp fuse that people online say controls the power windows in the driver's compartment. I am also getting power to the blue wire with the black stripe leading into the drivers cluster I cannot figure out why my windows are not working.
WEST201
  • 8 POSTS
Are you stumped too
CARADIODOC
  • 33,755 POSTS
Activate the driver's window switch while measuring the voltage on the black wire at that switch assembly. All voltage measurements should be done with that switch plugged in, to be accurate. Back-probe through the back of the connector next to the wires.
WEST201
  • 8 POSTS
Yes there ias power on both ends of the wire
ILITMAN
  • 2005 MERCURY MOUNTAINEER
  • 120,000 MILES
2005 Mountaineer V8. Audio and accessory delay still work. I'm thinking its not the 60 amp fuse. Your thoughts?
BMRFIXIT
  • 19,053 POSTS
Start checking fuses and than driver door harness
WEST201
  • 8 POSTS
Please help
