Cheers
Images (Click to make bigger)
SPONSORED LINKS
Saturday, November 27th, 2010 AT 1:41 AM
BECKYSTX
MEMBER
1 POST
1998 MAZDA PROTEGE
4 CYL
2WD
AUTOMATIC
220,000 MILES
Need to know where the fuel filter is located on 1998 Mazda Protege
Wednesday, May 19th, 2021 AT 3:27 PM
(Merged)
WRENCHTECH
MECHANIC
It's mounted right in the back of the engine compartment. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
RAMESH63
MEMBER
1991 MAZDA PROTEGE
Could you tell me where the fuel filter located in my car and how to change it. I was told to try changing this, since my car recently appears to be shakey, something chocking feeling when I stop the car at the light, and runs smoothly when drive. Pl. Help.
Thanks
(Merged)
BLUELIGHTNIN6
MECHANIC
Under hood, driver side, rear engine area, passenger side of brake booster, mounted on firewall relieve fuel pressure then disconnect fuel lines at each end of filter to replace
