1996 Mazda B2300 Master Slave Cylinder & Clutch Hydraul
MELLOWDOG
  • 1996 MAZDA B2300
  • 4 CYL
  • MANUAL
  • 85,952 MILES
Hi Guys.
Well my truck is wearing on my wallet lately and its nickel & diming to death. Thus time im just needing sime good advice, Im getting ready to buy a new Clutch Hydraulic Hose and i can't find one locally and i have been searching the web and found a Centric Clutch Hose for $40.48 and im needing a honest Professional opinion to purchase it. I appreciate it as always and have a nice day.
http://www.theautopartsshop.com/Search/PartDetails.aspx?gPartNum=mazb2300/CE151.65029&proid=mazda+b2300+Clutch-Hydraulic-Hose+Centric+217574&Pat=auto+car-usa+Parts+Brand+PartDetails
Sunday, June 27th, 2010 AT 4:43 PM
  • 31,938 POSTS
Hi there,
Thank you for the donation,
Looking at the product you have in the link, I doubt that you will have any problem with it, anyway a 2 year warranty is a fair backup.
Mark (mhpautos)
Sunday, June 27th, 2010 AT 9:06 PM
CJCOLCLASURE
  • 1996 MAZDA B2300
  • 4 CYL
  • MANUAL
  • 172,000 MILES
Yes my truck has had trouble shifting gears, and I pretty much have no pedal. I figured that we needed to bleed the clutch to get air that was built up in the line out. I got to the bleed valve in the slave cylinder, loosened the valve but no fluid came out as it was supposed to. My main question is do I need to have the clutch in when I loosen the bleed valve for the fluid to drain?
Thanks.
Tuesday, July 30th, 2019 AT 2:34 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1505.jpg
GARION1987
  • 1994 MAZDA B2300
Engine Mechanical problem
1994 Mazda b2300 4 cyl Front Wheel Drive Manual 200k miles
ok I have a 94 Mazda b2300 and im sure it still has the original cluth.I have the clutch assembly kit. But I am having a little trouble finding instructions on how to go about replacing it and a list of what tools I will need. If you could provide me with that info or where to find it it would be much appreciated email is garion_r_brooks@yahoo. Com or facebook just search garion
Tuesday, July 30th, 2019 AT 2:35 PM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
First, a quick overview of what should be in a kit and the items to check and change.
A clutch kit should come with the following;
Clutch Disc
Pressure Plate
Pilot Bearing
Alignment Tool
Throwout Bearing
sometimes, High Temp Grease
On most 4 cylinders it is reccomended that the flywheeel be replaced if it needs a new surface, (if it is grooved, burnt or has a ridge), because they are too thin to resurface. Thisis because they are made to save on gas mileage and do not have enough material to have the surface re-machined.
You can get away with wet-dry or emery paer in a cross hatch pattern toi brake the galze and provide a new surface for the clutch to break into, it depends on how long you are keeping it, budget, etc.
Check the following and replace as needed;
Clutch master cylinder and Slave cylinder for leaks
Clutch hase for cracks and leaks
Pivot Arm itself and Fulcrum point for excessive wear
Replacing the clutch is as follows;
Remove clutch pressure plate in a pattern by incrementaly loosening every other bolt s to relieve spring pressure
Keep hardware in same plces they came from
Clean all surfaces and use hiogh temp grease on the Throwout bearing slide surface around input shaft
Install pilot bearing into flywheel
Grease Flucrum point of actuation arm
Install flywheel and torqu bolts to spec in star pattern
Do the same with Flywheel
Replace Clutch fluidas you would brake fluid by pumping and holding pedal to floor, with assistant help, until fluid is free of dirt and air
Tools needed;
Socket and ratchet set
Torque wrench
Clutch alignment tool, (if not included in kit)
Service manual or Haynes Service guide for manufaturer torque specs
Now is a quick overview.
Of course there are the inevitable variables. Tools needed to bleed out clutch system are same as brakes.
Let me know if you need anything else.
