ECM problem
EDGAR ARMENTA
  • 2007 SATURN ION
  • 2.2L
  • 4 CYL
  • FWD
  • 100,000 MILES
So I am having a problem with the ECM. There is no communication with it. I have a scanner and it does not let me communicate with the ECM either. The instrument panel does not turn on, the stereo does not either. The car turns but does not run. I replaced the ECM and the BCM, by turns the way the BCM is together with turns together the fuse box that goes under the dash, yet there is no communication with the ECM. I am struggling at this point and would really appreciate much help. Thanks.
Saturday, November 26th, 2016 AT 1:50 PM
SATURNTECH9
  • 30,869 POSTS
Does your cig port work because if that fuse is blown you cannot talk to you ECM etc. Also, if you replaced the ECM and BCM it wont start. You have to relearn the pass lock sensor. Also, did you put used BCM and ECM in it? What was wrong with you old ones?Because I highly doubt that they were both bad? Was the cluster working before you replaced them?
Sunday, November 27th, 2016 AT 9:13 AM
EDGAR ARMENTA
  • 27 POSTS
Also, the fuse box under the hood gets no current in the ignition and ecm fuses, the fuse box was also replaced, everything was replaced because the battery was connected backwards and the bcm, ecm and the stereo burned, and yes, all three are used.
Wednesday, January 4th, 2017 AT 5:16 PM
EDGAR ARMENTA
  • 27 POSTS
Another question about relearning the passlock sensor, if it's not programed yet should the car just crank, or should nothing happen when I attempt to start the car?
Wednesday, January 4th, 2017 AT 5:29 PM
SATURNTECH9
  • 30,869 POSTS
It might crank for a split second then it won't crank anymore.
Wednesday, January 4th, 2017 AT 6:39 PM
EDGAR ARMENTA
  • 27 POSTS
Car doesn't crank at all, passlock also turns off after turning the key on, only lights on are airbag and seat belt, with the scanner I can only get into the bcm, transmission, but between the ecm and the scanner there is no communication
Wednesday, January 4th, 2017 AT 7:00 PM
SATURNTECH9
  • 30,869 POSTS
Do you have power to the ecm fuse?Have you checked all the fuses?I suspect there is s blown fuse or fuseable link somewhere.
Wednesday, January 4th, 2017 AT 9:29 PM
EDGAR ARMENTA
  • 27 POSTS
Triple checked the fuses and only 9, 10 and 11 fuses which are ECM/ETC (9) EMISS (10) AND IGN (11). When I try turning the key to ignition the only thing that happens is the dash lights turn off but it doesn't even try cranking the engine, fuel pump doesn't activate.
Thursday, January 5th, 2017 AT 9:19 AM
EDGAR ARMENTA
  • 27 POSTS
Also getting 2 codes from the IP cluster: VIN information error (B1015) and Class 2 data link fault (U1000) U1000 dissappear when I close the key and open it again, but appears after about 5 seconds
Thursday, January 5th, 2017 AT 9:35 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked to make sure there is power going into the underhood fuse box?Power at that main cable where the nut holds it down?
Thursday, January 5th, 2017 AT 12:42 PM
EDGAR ARMENTA
  • 27 POSTS
Yes there is
Thursday, January 5th, 2017 AT 5:23 PM
SATURNTECH9
  • 30,869 POSTS
But there is no power to the ecm fuse in the underhood fuse box with the key in the run position?
Friday, January 6th, 2017 AT 6:51 AM
EDGAR ARMENTA
  • 27 POSTS
There are two fuses that mention the ecm, fuse 1:ECM/TCM and fuse 9:ECM/ETC only fuse number 1 is getting power, and fuse number 9 only gets power if I bridge relay 29:POWERTRAIN
Friday, January 6th, 2017 AT 10:48 AM
SATURNTECH9
  • 30,869 POSTS
Have you tried swaping the relay with a known good one?You could have damaged who knows what when you reversed jumped the car. Just had a car thru my shop that was reversed jumped that caught fire and the battery exploded.
Friday, January 6th, 2017 AT 1:02 PM
EDGAR ARMENTA
  • 27 POSTS
Already checked that.
When the computer is damaged, should the car still try starting?
And in the ignition switch, there is 5 cables, an orange (always has power) a blue cable and a grey one (get power when the key is open) a white one and a white/black cable (don't have any power, or ground to them, at any key position they don't get power, off, acc, I, or in the ignition. Could this be a problem to the car not starting?
Friday, January 6th, 2017 AT 3:31 PM
EDGAR ARMENTA
  • 27 POSTS
Here's a picture of the cables.
Friday, January 6th, 2017 AT 3:33 PM
SATURNTECH9
  • 30,869 POSTS
Here's the problem the starting system goes thru computer's even to operate the starter. Do you have a scan tool that can read like the engine and body control module codes?I know you can't talk to the ecm and we don't know about if you can talk to the bcm?If the ecm isn't getting power it won't start regardless. If your getting power into the underhood fuse box itself and your not getting power to some of the fuses. Then your gonna have to starting looking at the wires going into the underhood fuse box.
Friday, January 6th, 2017 AT 7:59 PM
LEWISFERGUSON1
  • 0 POST
My dad did the same thing to my Ion. It wound up being a bad wire to the ignition switch.
Monday, June 3rd, 2019 AT 7:37 PM
JOE1953
  • 619 POSTS
  • 2006 SATURN ION
  • 2.2L
  • 4 CYL
  • FWD
  • 166,000 MILES
When I try to read the codes on my car with my actron autoscanner cp9135 it show link error try again but I can use my scan tool on another car it will scan the codes and I can use some one else scan tool on my car it will read the codes why I am getting the link error?
Monday, June 3rd, 2019 AT 7:38 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
So someone else's scan tool will read codes on your car? But your scan tool won't read codes on your car?If so then your scan tool does what Alot of generic diyer scan tools do Hit and miss on what cars they link to and read codes.I have had that happen before with one of my cheap generic code reader.
SATURNTECH9
  • 30,869 POSTS
Also you have to be careful you don't get a China knock off one. Those no telling what cars they work on or how long they work.I have a autel Al319 it has a color screen reads some live engine data and works really good. It's from a USA seller marketer though. There are tons of the Chinese knock off ones that are cheaper and look the same but are junk. For the good ones like mine there under 40 for the USA market ones. Did you ever fix your p0128 code on that car?
