Heater core
THELITTLES
  • 2002 LINCOLN TOWN CAR
Heater problem V8 Two Wheel Drive Automatic
Can you please tell me how to change my car's heater core. Thank you! I love this site.
Wednesday, October 1st, 2008 AT 2:47 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
This jog is not to bad, it will take a little time but well worth the money you will save doing the job. Here is a guide that will give you an idea of what you are in for doing the job.
https://www.2carpros.com/articles/replace-heater-core
You might what to replace the heater core hoses as well
https://www.2carpros.com/articles/replace-heater-hoses
Here is what the job will be like for your car (below)
Cheers, Ken
Monday, November 13th, 2017 AT 5:17 PM
HMAC300
  • 48,601 POSTS
To by pass just get a piece of pipe that fits on hoses and clamp it on both ends with hoses. To replace the heater core the dash has to come out.
Monday, November 13th, 2017 AT 5:18 PM (Merged)
JDUB75925
Thanks buddy I'll try it when I get off work where would the hoaea be located
HMAC300
  • 48,601 POSTS
The hoses will connect behind the motor.
CLON
  • 4.6L
  • V6
  • 120,000 MILES
How do you replace the heater core in a 2002 towncar cartier
BILLYBOB09
  • 1998 LINCOLN TOWN CAR
  • V8
  • 97,700 MILES
Heater problem
1998 Lincoln Town Car V8 Two Wheel Drive Automatic 97700 miles
I would like a step by step process on how to replace the heater core on a 1998 Lincoln Town Car. It would also be helpful if possible, to have diagrams as well.
Thanks in advance.
POPPYJOHN
  • 2000 LINCOLN TOWN CAR
  • 4.6L
  • V8
  • 150,000 MILES
Have everything off, dash is loose except drivers side, does steering have to be dropped completely down, and is there something else I'm not seeing. Thanks
HMAC300
  • 48,601 POSTS
Yes it has to come out. See pics
POPPYJOHN
I don't see any pictures
HMAC300
  • 48,601 POSTS
They are there unless there is an x in a box. Click on them and try to enlarge them so you can read it easier. I can't do much on this end with that.
WESTSIDEAUTO
  • 1999 LINCOLN TOWN CAR
Heater problem
1999 Lincoln Town Car V8 Front Wheel Drive Automatic
how do you change a heater core in a 99 towncar with air
RACEFAN966
  • 5,029 POSTS
This is an 8.2 hour job for a shop to do so it is no easy task. There are way to many things to try to tell you to do that have to be done right so that you don't deploy the air bags and so on. So I either recomend that you go to your local parts store and buy a repair manual like haynes or chilton so you have all the steps as you need to remove the entire dash board to get to it or find a trusted shop and let them do it. I am sorry I can't give much more but like I said it is just so much to try to tell on how to replace it, that it would take hours just to write it out. Once you have a book if you get stuck in area's then get back to me and I will try to walk you through it.
GILSON_AND
  • V8
How can I change the heat core
Monday, November 13th, 2017 AT 5:19 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
O.K. Major job instrument panel needs to be removed if you attempt get a manual and take your time
2CP-ARCHIVES
  • 4,540 POSTS
  • 12,000 MILES
Im replacing the heater core, but I need to know if it's a 6" or 7"?
  • 52,797 POSTS
By matching it up or by using the vin number to verify the correct core.
