Where is the Knock sensor on the 4.0L V6? Do the Heads have to be pulled to replace the sensor?
Tuesday, May 3rd, 2011 AT 2:08 PM
MECHANIC
Looks like they recommend removing the cylinder head to replace them but I have replaced them without. It is actually located under the intake manifold, but appears to be trapped until the head is removed, but like I said you can do it without removing the heads. See the attachments below for instructions on replacement.
Images (Click to make bigger)
SPONSORED LINKS
Saturday, July 2nd, 2011 AT 1:01 PM
ANTHONY STAMATION
MEMBER
1 POST
2003 TOYOTA 4RUNNER
3.0L
6 CYL
2WD
AUTOMATIC
129,000 MILES
So I am throwing a code for my knock sensor I figured out that the knock sensor is or should be located underneath my intake manifold. I just need to know which side of the engine? The battery side which is the left and driver side or the alternator side.
Friday, October 12th, 2018 AT 6:03 PM
(Merged)
HMAC300
MECHANIC
There are two knock sensors which you will see in picture. This is a 4.0L not a 3.0L do not over torque these as it can damage them. 15 ft lb or 20NM.
Image (Click to make bigger)
(Merged)
HECK2
MEMBER
1 POST
2002 TOYOTA 4RUNNER
6 CYL
4WD
AUTOMATIC
193,126 MILES
I"m trying to locate the knock sensor on a 2002 toyota 4runner
(Merged)
MECHANIC
Hi there.
Check this post I think it should be the same as your's, I will re check Mitchell 1 for your exact year and advise if different, I won't be able to do that for a few hrs though.
Mark (mhpautos)
P.S Raz has posted what I was going to add, so check yours against the pic.
SPONSORED LINKS
(Merged)
WATERFALLS
MEMBER
1 POST
1996 TOYOTA 4RUNNER
Engine Mechanical problem 6 cyl Two Wheel Drive Automatic 213000 miles
I need to know the location of the knock sensor on a 4runner 3.4L sr5 2wd
This site rocks BTW
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
The knock sensor is located under the intake manifold. Here are some diagrams (below) plus a guide that will give you an idea on what you are in for when removing the intake to replace the knock sensor.
