2000 Jeep Cherokee idle
DIESELCJ
  • 2000 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 100,000 MILES
Jeep stalls and wont idle runs great on the highway
Do you
have the same problem?
Monday, December 7th, 2009 AT 8:20 PM
BLACKOP555
  • EXPERT
Check and clean out the throttle plates and make sure its completely closing. Check the vacuum lines for leaks. Also take out the idle air motor make sure the pintle on it is moving freely. And the ports where it hooks up on throttle body is clean.
Monday, December 7th, 2009 AT 9:45 PM
CHULEGAARD@HOTMAIL.COM
There are two sensors on the Throttle Body one is idle the other is throttle position, cheap easy fix
Wednesday, December 9th, 2009 AT 4:44 PM
Recommended Guides
