P0300 code why can we fix it?
DTOMLIN9365
  • 2005 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 43,100 MILES
Engine falls flat under load and sounds like spark knock checked for codes and got code p0300 multipel misfires changed plug did not help
Thursday, May 6th, 2021 AT 12:58 PM (Merged)
  • 108,334 POSTS
They are two different items. The knock sensor's job is to keep engine timing at it optimum position, just before you get valve ping. Here is a picture:
https://www.2carpros.com/forum/automotive_pictures/249084_5_28.jpg
DTOMLIN9365
Went to shop and ask about knock sensor mechnic put tester on and drove said knock sensor was working and that he thought maybe converter had came apart but no codes for o2 only codes we get are maf vaf the misfire p0101 andp0300
  • 108,334 POSTS
Have you tried cleaning the MAF?
DTOMLIN9365
Put new one on that fixed it, thank you.
JVORZELL
  • 5 POSTS
  • 2004 CHEVROLET SILVERADO
  • 5.3L
  • V8
  • 4WD
  • 263,500 MILES
Engine started running really rough especially at idle. Kicks up a code P0300 tends to stall out when you rev the motor and let it drop down. Found a crack in the PCV valve connection tube replaced that. Still runs rough. I've been running this program iobdwiz from scantool. Net checking the fuel trims and stuff like that and find the fuel trims go double digit positive sometimes on the long-term. Replaced the plugs wires, checked the coils they all seem good. Injectors seem good sound. Good 02 sensors voltage goes up and down. Any suggestions of what I should be checking next?
Thursday, May 6th, 2021 AT 12:59 PM (Merged)
  • 108,334 POSTS
Welcome to 2CarPros.
If the fuel trims are that high, something is allowing unmetered air into the engine. How did you check for vacuum leaks? I know you repaired the PCV, but did you check the intake? Also, are there any exhaust leaks pre catalytic converter? Is fuel pressure within spec?
I have one other thing I would like for you to review. It deals with issues specific to a random misfire. Read through it and see if it is helpful for you.
_______________________________________
2004 Chevy Truck Silverado 1500 4WD V8-5.3L VIN T
Important Information - PIP 3056
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0300 Important Information - PIP 3056
IMPORTANT INFORMATION - PIP 3056
Subject: 97-05 Vehicles with 4.8 5.3 5.7 and 6.0 Gen III V8 Engines and Misfires on One Bank - kw CEL diagnostics driveability DTC P0171 P0172 P0174 P0175 P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 #PIP3056 - (07/12/2004)
Models: (00-05 Cadillac Escalade - C6 and K6) and (02-05 Chevrolet Avalanche - C1, C2 K1 and K2) and (99-05 Chevrolet Silverado - C1, C2 K1 and K2) and (00-05 Chevrolet Suburban - C1, C2, K1 and K2) and (00-05 Chevrolet Tahoe - C1 and K1) and (99-05 GMC Sierra C1, C2 K1 and K2) and (00-05 GMC Yukon - C1, C2, K1 and K2) and (03-05 Chevrolet Express G1, G2, G3, H1, H2 ) and (03-05 GMC Savana G1, G2, G3, H1, H2 ) and (04-05 Buick Rainier S1, T1 ) and (03-05 Chevrolet Trail Blazer EXT S1, T1 ) and (03-05 GMC Envoy XL XUV S1, T1 ) and (03-05 Hummer H2) and (04-05 Cadillac CTS-V DB) and (98-02 Chevrolet Camaro FB) and (97-04 Chevrolet Corvette YB) and (98-02 Pontiac Firebird FB) and (04-05 Pontiac GTO VB)
The following diagnosis might be helpful if the vehicle exhibits the described symptoms.
Condition/Concern:
Check Engine Light with a P0300 due to 2 - 4 cylinders misfiring on the same bank of the engine. DTCs P0171, P0172, P0174 or P0175 may also set for the misfiring bank.
Recommendation/Instructions:
If the published misfire diagnostic does not isolate the cause, perform the following suggestions as necessary:
- Perform a fuel injector balance test for all 8 cylinders. If a fuel injector concern exists, it is possible to misfuel an entire bank of the engine, causing multiple cylinders on the same bank to misfire even though the root cause is a single fuel injector.
- Inspect O2 sensor connections on the misfiring bank for corrosion or water intrusion. If water intrusion is found on the right bank, it may be due to the AC Evaporator Condensation dripping onto the O2 sensor harness. If this condition is found, reposition and shield the harness to prevent a repeat concern and repair the connections.
- Check for excessive exhaust backpressure using the restricted exhaust diagnosis.
- Swap the Position 1 O2 sensors side to side to see if the misfires move to the other bank of the engine. If so, replace the O2 sensor.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
NOTE: GM bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition.
___________________________________________
DPONCAR
  • 2002 CHEVROLET SILVERADO
  • 6.0L
  • V8
  • 4WD
  • 200,000 MILES
I was trying to fix the problem with the service engine soon light coming on and blinking and showing code p0300. I was attempting to try cleaning the ground (g103 I believe) and dropped the bolt somewhere and haven, t been able to find it. I was hoping someone would tell me what size it is so I can replace it and see if the problem is fixed.
CARADIODOC
  • 33,757 POSTS
Code 300 is for a random cylinder misfire. That's not a ground issue. Start with spark plugs and wires. You didn't list the engine size or mileage so I can only make generalizations. A flashing Check Engine light indicates the most serious of diagnostic fault codes. It means you're supposed to stop the engine right away because too much raw, unburned fuel is going into the exhaust system where it will burn in the catalytic converter and overheat it.
For the bolt, on cars and trucks they're often odd sizes compared to what you can buy at a hardware store. You're better off getting the right one from a salvage yard.
MACFIN
  • V8
  • 4WD
  • 54,000 MILES
I looked through the Repair Question Forums and do not see anything specific that helps answer what might be wrong with my vehicle so now I am sending my question to you and very much hope that you may be able to help. I have a 2002 Chevy Silverado Pick-up Truck. V8, 6.0 liter engine, K2500. 4 Wheel Drive. Automatic. 54,000 miles. Check Engine Soon light is blinking. Code P0300 Random misfire. Light does not come on at all while driving around town. Only comes on when on the highway at over 60 mph. The light blinks for several minutes and then eventually goes out. Then several minutes later it comes back on blinking again. When the light comes on, the truck continues to run smoothly and there is no indication that something is wrong.
I brought the truck to be serviced. They replaced Intake manifold gasket with new design. (They said there is a bulletin out from GM that if the gasket is the color green then it could become defective. They said my truck had the green one.) The garage seemed to assume that because of this bulletin that this must be what was wrong. They also did an oil and filter change and changed all eight Spark Plugs. ( My truck had 100,000 mile spark plugs so I'm not sure why they needed to change the spark plugs now).
The next day, I went on the highway with the truck and once again the light was blinking. I called the garage and they said to bring it back and they would check every thing again. At this time they rechecked the connections to intake and cleaned engine grounds and also replaced the fuel filter. When I picked up the truck, they said everything should be fine now. I took it on the highway and again the light was still blinking. I called the garage again and they said to bring it back. When I picked up the truck they said they once again checked everything and it now definitely should be fine. I went on the highway and the light is blinking on again.
I'm very frustrated and aggravated. It cost me almost $540.00 and I am feeling that bringing my truck to this garage might have been a waste of time and money because they did not solve the engine light problem. I'm thinking that they are not following diagnostics thoroughly to solve the problem. The second time I brought the truck back, I felt like I was being brushed off. They don't seem to be doing anything more about it. I don't know what to do next.
Also, prior to having this service engine light problem, I had this vehicle at the dealer and was told the Engine Oil Cooler Lines are starting to leak. They said they would need to replace the hose. The garage that I brought the truck to for the engine light said that this would not affect the light coming on and it is a separate problem. True?
One other thing I can think of mentioning: When I first start driving the vehicle I can hear a engine tapping type of noise but again I think this might be a separate problem. (I told the garage this as well.)
I am hoping you could give me some insight on what might be wrong. I would really appreciate any suggestions. I'm really discouraged! Please help!
Thursday, May 6th, 2021 AT 1:00 PM (Merged)
MERLIN2021
  • 17,250 POSTS
This is most likly the cause, and the fix is free:
This is a TSB also from Chevy:
Information on Engine Misfire MIL/SES Light Illuminated or Flashing DTC P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, P0420 or P0430 TECHNICAL SERVICE BULLETIN Reference Number(s): 06-06-04-046, Â Date of Issue: Â September 12, 2006 Related Ref Number(s): 06-06-04-046 ARTICLE BEGINNING
SERVICE INFORMATION If you encounter vehicles that exhibit the above conditions, refer to SI for the appropriate DTC(s) set. If no trouble is found, the cause may be due to an ECM ground terminal that has corroded with rust over time. Inspect the main engine wiring harness ground terminal (G103) for this condition. The wire terminal (G103) attaches either to the front or to the rear of the right side cylinder head, depending on the model year of the Full Size Pickup and/or Utility Trucks. If the ECM ground terminal has been found to be corroded, then follow the service procedure outlined in this bulletin to correct the corrosion issue. Fig. 1: Engine Wiring Harness Ground Terminal Location (2007 Full-Size Pickup and/or Utility Trucks) Courtesy of GENERAL MOTORS CORP. Fig. 2: Engine Wiring Harness Ground Terminal Location (1999-2006 Full Size Pickup and/or Utility Trucks) Courtesy of GENERAL MOTORS CORP. 1. Remove either the nut or bolt securing the main engine wiring harness ground terminal (G103) to the right cylinder head. Refer to the above illustration to determine where the ground is located on the vehicle (1). 2. Remove all rust from the ground terminal, the cylinder head and the retaining nut or bolt. 3. Position the main engine wiring harness ground terminal and install the nut or bolt. Tighten: Tighten the retaining nut or bolt to 16 N.M (12 lb ft). 4. Apply some type of electrical moisture sealant to protect the harness terminal from further corrosion.
MACFIN
Hello merlin2021,
Thank you so much for your very prompt response. I really appreciate it. The garage had said that they cleaned engine grounds but I will double check the EMC ground terminal and will remove all rust if found. Hopefully, this is the problem. I will let you know if it worked.
Thanks so much!
Macfin
JOEL_93
  • 4.8L
  • V8
  • 165,000 MILES
It says multiple misfire detected. What can be the problem?
SCGRANTURISMO
  • 4,897 POSTS
Direct Trouble Code (DTC) P0300 can be set by a variety of conditions. In the diagrams down below I have included the factory diagnostic troubleshooting guide for DTC P0300 for your vehicle. Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
JOEL_93
Okay, I will check it out. Thanks
  • 52,797 POSTS
Good evening.
Just to throw another idea at you, check the fuel pressure. That is the most common cause for this code. If the pressure is low, it will cause multiple misfires.
ROWTIEAR
  • 91 POSTS
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 65,000 MILES
Code p0300.
Engine is misfiring on #2 and #7 cylinder at idle.
So far I have checked compression 155 and 160
switched coil, plug wire, plug and injector.
Checked fuel pressure 55-60 psi.
Checked EGR.
Checked for plugged exhaust.
Changed both rear o2 sensors.
Compared all scanner data with another truck that is known to be operating properly
the only difference noted being bank#2 sensor#2 is staying down around 100-200 mv.
At 1 point there was a map sensor code.
I suspected a possible cracked or leaking upper intake.
But when I called the dealer they told me they had never sold one or even priced one before. I'm running out of things to check.
Does anyone have any more ideas?
Thanks in advance.
FISHERMAN
  • 937 POSTS
Hello !!
Cyl #3 and #7 are in the same side..
not next to each other...
https://www.2carpros.com/forum/automotive_pictures/576_0_13.jpg
On the same side on the distributor cap...
Did you replace the "cap"
How about the spark plugs?
When did you replace them?
Are the correct "heat"?
Did you check the pick-up coil?
could be "missing" at low RPM`s
Let me Know and I`ll be thinking about it..
BTW thanks a Lot for your donation!!
ROWTIEAR
  • 91 POSTS
Hello and thanks for responding
The spark plugs are approx. 2 months old and installed by myself at the shop where I work.
I am also a tech
The 5.3 litre is d.I.S. "One coil per plug"
#2 cyl and #7 cyl are the problem cyls
I am aware that they are on opposite ends of the engine.
The only thing I have found is that they follow each other in the firing order but I can't see the crank sensor causing the problem on just the two cyls.
Any other input would be appreciated.
FLEXY5
  • 512 POSTS
Replace the intake gaskets, not the intake. That should fix your problem. You were getting a MAP code because the engine is sucking unmetered air, more that what the computer thinks should be. Basically, your computer is confused. It is taking the readings from the TP and O2 sensors and says that the intake should be sucking a certain volume of air, based on MAF. When you have an intake leak, it produces a lower vacuum that what the computer thinks it should, making the computer think that the MAP is bad. This also explains the O2 sensor reading (which is lean). The engine is sucking more air than what the computer can compensate for. Hope this helps. If you need any more info, don't hesitate to ask.
Dave
