Input speed sensor location not vss
BILLHVAC
  • 2003 BUICK CENTURY
  • 3.1L
  • 6 CYL
  • 175,000 MILES
I have no speedometer. Will not shift out of first gear. I have replaced VSS and PCM. Still no change. I need to know where transmission input speed sensor location to install new one. Please help.
Sunday, June 25th, 2017 AT 5:29 AM
WRENCHTECH
  • 20,757 POSTS
It is number 440 in this picture but that sensor will have no effect on the speedometer.
https://www.2carpros.com/images/external/105997639.gif
Sunday, June 25th, 2017 AT 8:59 AM
BILLHVAC
  • 8 POSTS
I have checked fuses. It was shifting a little high periodically. Do you. Have any advice. I am inching it to transmission. Shop tomorrow. Thanks
Sunday, June 25th, 2017 AT 9:22 AM
BILLHVAC
  • 8 POSTS
No DTC codes.
Sunday, June 25th, 2017 AT 9:24 AM
WRENCHTECH
  • 20,757 POSTS
That input sensor could effect your shifting problem but it has no effect on speed readings. If you are still having speedometer issues, you could have wiring problems or a defective output sensor. You really need a lab scope to test the signal coming out of the VSS sensor.
Sunday, June 25th, 2017 AT 9:25 AM
BILLHVAC
  • 8 POSTS
Thanks.
Sunday, June 25th, 2017 AT 9:29 AM
BILLHVAC
  • 8 POSTS
I have replaced VSS. No change.
Sunday, June 25th, 2017 AT 10:21 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,960 POSTS
There is a fuse 10 amp hot when cranked over that sounds like it might be blown. Here is a wiring diagram for the cluster (below) so you can do some testing.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
Tuesday, June 27th, 2017 AT 1:56 PM
BILLHVAC
  • 8 POSTS
I feel a little stupid and relieved. It was a broken wire to vss
Tuesday, June 27th, 2017 AT 7:51 PM
KEN L
  • 42,960 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Wednesday, June 28th, 2017 AT 11:15 AM
JUSTIN WEEKS
Need help finding input speed sensor on 99 buick century 3.1 v6, I repllaced output sensor but need to replace input having shifting issues plz help. Code pulled p0502
Wednesday, January 16th, 2019 AT 6:57 PM
KEN L
  • 42,960 POSTS
This car does not have a input shaft speed sensor here are the transmission wiring diagrams to confirm the issue so you can see how it works. P0502 is for the VSS I would use this guide and the wiring diagrams to confirm the connection between the sensor and the PCM
Check out the diagrams (Below). Please let us know what you find.
Thursday, January 17th, 2019 AT 10:51 AM
JAZZMINM21
I need to find the input speed sensor on a 2001 Buick Century
Saturday, August 17th, 2019 AT 11:49 AM
KEN L
  • 42,960 POSTS
It looks like it is in the same please as newer models check the diagrams above and below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, August 18th, 2019 AT 12:01 PM
ERICBOSTWICK
  • 2002 BUICK CENTURY
  • 3.6L
  • V6
  • 180,000 MILES
Cannot find location of the input sensor.
Tuesday, November 26th, 2019 AT 7:59 PM (Merged)
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The vehicle speed sensor (VSS) is located on transaxle right axle case extension.
If you are wanting to replace it, it is probably best to remove the right front wheel to gain access.
Then simply unplug the harness connector, then unbolt the sensor and do not forget it has an o-ring. To install, reverse order. Tighten the bolt to 8 ft lbs.
ERICBOSTWICK
I am looking for the input speed sensor not the output.
KEN L
  • 42,960 POSTS
It inside the transmission pan near the valve body. This guide will help you see what you are in for when dropping the pan so you can change the sensor out with diagrams below on how to do the job and the sensor location.
Cheers, Ken
