Rear window defogger relay located?
GUY_FROMMN
  • 2006 HONDA CIVIC
  • 80,000 MILES
My rear defogger doesn't work anymore. The light turns on when I push the button, but the defogger never warms up. My thinking is that the relay is possibly bad as I've checked the fuse and it is not blown. There are a bunch of relays under the hood in the fuse box except there is not a description of which one does what. If one of these relays is for the rear defogger and you can point out which one it is, I will be most grateful. I worry the dealership will charge a lot for testing etc. And a few bucks for a new relay is worth trying first. Also, it is a Civic Si if that makes any difference.
Tuesday, November 29th, 2011 AT 8:15 PM
RIVERMIKERAT
  • 6,110 POSTS
THe relay for the rear window defogger is under the hood in the relay center here is a guide to help you test it and the location of the relay in the diagrams below.
Tuesday, November 29th, 2011 AT 8:43 PM
ALTERP
  • 2001 HONDA CIVIC
Electrical problem4 cyl Front Wheel Drive Automatic 99068 miles
Hello
My rear window defogger quit working. Grid is in good shape, no nicks etc. All wires attached. 40 amp fuse under hood fuse box replaced. Yellow indicator light works when rear defrost button pushed. What fuse is the proper fuse to check under dash. What else may be problem
Thanks
Monday, October 8th, 2018 AT 5:24 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,057 POSTS
Fuse/relay box under hood, check fuse #11 30A and rear window defogger relay. Also check fuse box under the dash driver side fuse #14 10A.
The is a relay that needs to be checked here is a guide to help you see whats wrong.
Check out the diagrams (Below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
CARTIERANDREA
  • 2005 HONDA CIVIC
Electrical problem
2005 Honda Civic 4 cyl Automatic 70000 miles
my rear defrost only works on the bottom half of the window. Can you help me
BLUELIGHTNIN6
  • 16,542 POSTS
You will need to repair the metal lines that you see running across the rear windshield. You can purchase rear defroster repair kits at most auto part stores or order than from sites such as ebay. Com. Its pretty simple to fix and relatively cheap.
CARFIXING
  • 1989 HONDA CIVIC
  • 4 CYL
  • FWD
  • 192,000 MILES
I just got this car and it the rear window defrost wiring the main wire has come of the window how do I if I can fix this so I can defrost my rear window this coming winter
BLUELIGHTNIN6
  • 16,542 POSTS
You mean the little metal piece with the wire on it has came off of the glass? If so then it can be soldered back on or you can purchase a defrost repair kit which comes with special epoxy for this issue.
