1997 Honda Civic my signal light wont blink
MARKGIL15
  • 1997 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 109,000 MILES
I have a Honda civic hatchback 1997. All the lights are working if my park light is on. Even the signal light is on, but if I turn the signal to either side it wont blink the front and the back signal. I have no idea which is broken because all lights are working it just dont blink. I hope you guys can help me with my problem. Thank you so much
Do you
have the same problem?
Thursday, June 11th, 2009 AT 11:22 PM
BLUELIGHTNIN6
  • EXPERT
Do the hazard lamps work?
Thursday, June 11th, 2009 AT 11:25 PM
MARKGIL15
After received your answer to my question. I run to my car and test it the hazard if its working, and it works, but after proximately ten sec. It stop and it wont work anymore. So now both signal light and the hazard wont work. What would be the problem.
Thursday, June 11th, 2009 AT 11:42 PM
BLUELIGHTNIN6
  • EXPERT
I would suspect a faulty turn signal / hazard relay. The hazards and turn signals both run off of the same relay. It is located behind the left side of the dash, on front of the underdash fuse/relay box.
http://www.2carpros.com/forum/automotive_pictures/261618_Graphic_34.jpg
Thursday, June 11th, 2009 AT 11:45 PM
MARKGIL15
So what should I change. Can u tell me what u think that I would have to change to fix it. What do u think the broken specifically. Thanks
Thursday, June 11th, 2009 AT 11:52 PM
BLUELIGHTNIN6
  • EXPERT
The relay. Replace the faulty flasher relay
Thursday, June 11th, 2009 AT 11:56 PM
MARKGIL15
Ok thank you so much. I will buy tomorrow and I email u again. Thank u so much
Friday, June 12th, 2009 AT 12:00 AM
BLUELIGHTNIN6
  • EXPERT
You're welcome
Friday, June 12th, 2009 AT 12:01 AM
MARKGIL15
So. I bought a new flasher relay in kragen. And it fits and I guess it is the right one, but still the signal lights didnt blink. Do still have idea what would be the problem?/.U think it could be the rear signal bulb?/. Because it didnt work if im in park mode, but it suppose to blink fast if I have a bulb problem right?/. Im confuse. Give me more I dea pls. Thanks.
Saturday, June 13th, 2009 AT 6:05 AM
Recommended Guides
