HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Engine
Symptoms
Oil Leak
1995 Honda Civic Engine
LSWEESEL3
MEMBER
1995 HONDA CIVIC
4 CYL
FWD
AUTOMATIC
210,000 MILES
I just had a used engine with 80,000 miles on the used engine. What are some of the reasons it would leak oil?
Monday, June 7th, 2010 AT 10:19 AM
F4I_GUY
MECHANIC
Worn out seals, faulty oil drain plug gasket or oil filter.
If the PCV system is malfunctioning your seals/gaskets have a higher chance of leaking. So ensure the pcv system is working.
Monday, June 7th, 2010 AT 6:40 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
Oil Leakage Problem
I Have Honda Civic 95 Ex Model, It Was Going Very Fine Few Days Before, But My Car Gas Kit Was Got Burn So I Need To Get It Change By...
Asked by
Mirza Farrukh
1995
HONDA CIVIC
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
1995 Honda Civic Oil Leakage
Ive Had My Civic For About 5 Years Now, It Has Never Leaked This Much Oil Until Now. I Went And Got An Oil Change Six Months Ago, And It...
Asked by
quicks29
1995
HONDA CIVIC
1995 Honda Civic Major Oil Leak
My Honda Civic Is Leaking Oil Excessivly Out Of What I Think Is My Spool Valve. Im Not Sure Why It Is Doing This But When My Engine Is On I...
Asked by
gsean44
1995
HONDA CIVIC
1995 Honda Civic 1995 Honda Civic Oil Leak
Just Bought A 95 Civic To Use As Work Beater. Doing Tune Up And Changed Plugs Today. Middle Two Plugs Had Oil Almost Covering Their Tops...
Asked by
JRHunter
1995
HONDA CIVIC
I Had My Oil Changed At The Dealer 09/08 And Have Only Been Around 1,000 Miles. I Noticed A Smell The Other Day And Today I Realized I Was...
Asked by
hollister1892
1 ANSWER
1995
HONDA CIVIC
VIEW MORE
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Can You Fix a Head Gasket with a Sealer?
