Turn signal turns not working?
COLUMBIAN
  • 2004 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 120,000 MILES
I was rear ended at very low speed, nothing happened to the car but my turn signal stopped flashing. Lights turn on but it does not flash even for hazard light. What is wrong and how can I fix it?
Wednesday, June 2nd, 2010 AT 6:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating!
The most likely culprit here would be a faulty Turn signal/ Hazard Relay. Your vehicle's turn signal / hazard relay is located in the under-dash fuse / relay box. That box will be found under the left side of the dash.
Friday, November 2nd, 2018 AT 7:47 PM
COLUMBIAN
  • 15 POSTS
It appears no one carries relay for turn signal for 2004 Honda Civic-VP. Went to a dealer they said it would be $40 and they will have to order it.
I was surprised that with small rear end impact how would this relay blow out. SO I checked all wires of rear turn signals and near the relay which is under the dash. Made sure they are tight. Guess what the turn signal is flashing again properly.
Lesson lerned make sure all your wiring is connected properly, I guess even smallest disconnection might cause flasher not to flash.
LISA LARA
  • 2004 HONDA CIVIC
  • 4 CYL
  • 250,000 MILES
I have a 2004 honda civic and the blinkers will not flash. The hazzards work fine. What is it?
Tuesday, May 26th, 2020 AT 11:57 AM (Merged)
  • 108,320 POSTS
If they come on and won't flash, replace the signal flasher.
CRISTINACL
  • 2002 HONDA CIVIC
  • 4 CYL
  • 98,000 MILES
I have a 2002 honda civic lx the blinkers arent working we replaced the bulbs and checked the fuses but they still arent working
Check the turn signal/hazard flasher unit in underdash fuse/relay box
ACADIAN
  • 5 POSTS
  • 2001 HONDA CIVIC
Electrical problem
2001 Honda Civic Automatic 68000 miles
Hi I had a question about my 2001 honda civic. My turn signals sometimes work and sometimes dont. We I put the turn signal it will blink and then sometimes stop working when I am waiting to turn. Sometimes it also come back on, by itself. Any suggestions.
KHLOW2008
  • 41,814 POSTS
Hi acadian,
Does it happen when turned to either side or only one side?
It could be a bad/loose connection somewhere or a faulty switch or relay depending on what the hazards do when it is malfunctioning
ACADIAN
  • 5 POSTS
Yes it happens when I turn to either side
KHLOW2008
  • 41,814 POSTS
Hi acadian,
Does it stop blinking with the bulbs lighting up? Does the hazard lights operate properly?
ACADIAN
  • 5 POSTS
Hi, the hazards operate properly, but when the lights stop blinking the lights turn off, they dont stay llite.
KHLOW2008
  • 41,814 POSTS
If the hazards stops too, then the relay is bad.
Tuesday, May 26th, 2020 AT 11:58 AM (Merged)
ACADIAN
  • 5 POSTS
I was wondering what is the relay. Thanks
ACADIAN
  • 5 POSTS
Its me again. I was wondering what the relay is because now my hazards are not working all the time. Thanks
KHLOW2008
  • 41,814 POSTS
Hi acadian,
It is the Turn signal/Hazard relay.
https://www.2carpros.com/forum/automotive_pictures/192750_Fusebox01CivicDash02_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_Fusebox01CivicDash01_1.jpg
STACEYP1
  • 2001 HONDA CIVIC
My turn signals and hazard lights stopped working. Do I need to replace the relay assembly?
F4I_GUY
  • 3,302 POSTS
Yes it could be the flasher/hazard relay. Or it could be fuse #2 or #5 in the under hood fuse box. Here is a guide to help test the fuse and the fuse and flasher location below.
Check out the diagrams (Below). Please let us know what you find.
STACEYP1
Thank you for your response. I figured it out (me, a girl, using the internet-I did not take my car to a mechanic or the dealer). The flasher was in the fuse box under the steering column. I had to order the part from Honda, only $17.95, and I replaced the old one. Thanks for your help.
OLAMILEKAN
  • 1998 HONDA CIVIC
  • 124,000 MILES
The car comes with fuel smoke when raised and drive. The scanner shows the above code. We have changed the distributor and try the brain box and the injector mouth, still the fuel consumption did not change and the smoke keeps coming.
DJCL
  • 767 POSTS
Re is it smoking from? That code is for crank sensor. You will need a lab scope to check it @ the sensor look fore a good clean ac signal the connector is under the intake manifold it will be 2 wires if it checks out good @ the sensor you will need to check it @@ the computer
