2003 Honda Accord A/C
N.SAN
  • 2003 HONDA ACCORD
  • 4 CYL
  • FWD
  • 120,000 MILES
My a/c blows cold air when I'm driving on the freeway or when I press the gas but blows hot air when I slow down or stop.
Do you
have the same problem?
Monday, June 7th, 2010 AT 5:50 PM
F4I_GUY
  • EXPERT
If the fan is not cycling properly then incoming air will be warmer at idle.
Also, ensure that your a/c system is free of leaks and has enough R134a in it. (This has to be done by a licensed technician)
Monday, June 7th, 2010 AT 6:48 PM
N.SAN
The system has been checked and is free of leaks. It seems like when I press the gas pedal, it blows cold air but when I let go of the gas, it blows hot air. The a/c will only blow cold air when the gas pedal is pressed.
Tuesday, June 8th, 2010 AT 12:10 PM
Recommended Guides
