Transmission replacement?
VAL_MAR33
  • 1999 HONDA ACCORD
  • 6 CYL
  • 89,000 MILES
I need to change out the shift sensor but I cant find it can you help me please its driving me nuts! Its suppose to be on the trans! But its m.I.A! I think I need to replace the transmission?
Saturday, April 17th, 2010 AT 1:54 PM
KHLOW2008
  • 41,815 POSTS
Hi val_mar33,
It does sounds like the transmission could need replacement here are the instructions in the diagrams below. Check out the diagrams (Below). Please let us know what happens.
Tuesday, April 20th, 2010 AT 10:55 AM
RUDY2000
  • 1999 HONDA ACCORD
  • 2.3L
  • 4 CYL
  • 120,000 MILES
I recently replaced my transmission which is used on my accord 1999 with approx 120,000 km and my 1st and 2nd gear shifts are fine with no trouble but, my 3rd and 4th is delayed where my engine over revs and then shifts after 10 seconds of changing gears. Is it possible that there is an issue with the solenoid and which is it?
Tuesday, July 7th, 2020 AT 2:55 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
Was that the same problem with the old transmission? Also have you checked for trouble codes in the transmission yet? This sounds like a revolution sensor problem
RUDY2000
No, when the previous transmission comes to a stop, the transmission jerks very hard and goes to neutral and it had was tripping whan it had enough ATF and this is why I replaced it with another transmission.
SATURNTECH9
  • 30,870 POSTS
Alright have you checked for codes in the computer yet?
RUDY2000
I will when I get home, I was reading on other sites the shaft speeds sensor can cause this problem?
SATURNTECH9
  • 30,870 POSTS
These are the same sensor. Here is a video of the job being done.
https://youtu.be/f3bETtCIdxM
RUDY2000
Yep that did the trick once I replaced the sensor the transmission started shifting again.
Thanks for your help this site rocks!
SATURNTECH9
  • 30,870 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
98HONDA2009
  • 1998 HONDA ACCORD
  • 6 CYL
  • FWD
  • 190,000 MILES
I'll try to be brief. In 2008, I put in a low-milage transmission with a 90 day warrenty becasue I could not afford a new one. A few days after I got the car back, the key was stuck in the ignition and there was this pulling or tugging underneath the car everytime I reversed. It also was loud. Change the engines mounts, which were broken, and had the transmission examined for the tugging. Still nothing. It took the mechanic a year to figure out that I need a new wire installed that connects the gear to the ignition. Do you think that installing this wire will allow the key to release easlily and stop the tugging or pulling when I reverse? Is the ignition and gear somehow connected to the transmission? Do you think the wiring is off?
  • 108,192 POSTS
It could be a wiring problem. Today's transmissions have several electrical devices that make them shift, determine speed. And yes, wiring from the ignition sends power to it. However, I can't say for sure it will allow the key to come out easier.
DAHUA.HUANG
  • 1998 HONDA ACCORD
  • 6 CYL
  • FWD
  • 300,700 MILES
Hi, all
I have a big problem after rebuit trans.
Trans Tech rebuilt my trans one month ago.
They changed trans cluth kit and TC.
Good for two weeks (800 miles).
Then D4 light blinking and check engine on.
The car can not shift to 4th gear.
Checked trans oil level - good.
Back to shop. After scan.
They changed solenoid B and pick up solenoid.
Good for 50 miles. And D4 light blinking again.
I am not sure what happened in my car.
Thanks for your suggestion.
KHLOW2008
  • 41,815 POSTS
Hi dahua. Huang,
When the D4 light starts blinking, an error has occured and been detected by the PCM.
Get the Diagnostic Trouble Code and we will see what can be done.
BBUBACZ
  • 1997 HONDA ACCORD
  • 4 CYL
  • FWD
  • 172,323 MILES
Basically my question is regarding the cost to replace my transmission with a new (rebuilt) transmission from Honda.
I have a hum that I thought was the wheel bearings, so I had them replaced. The hum persists, and I also have transmission fluid leaking out from where the CV axle enters the trans. The leak is progressively getting worse. Also, I checked for play on the axles and they both move quite a bit. My understanding is that the carrier bearing is going causing the axle to shimmy allowing fluid to seep from the seal. The car has a lot of miles but its extremely clean and worth the money. Thanks in advance. Brad
Tuesday, July 7th, 2020 AT 2:56 PM (Merged)
  • 31,938 POSTS
Hi there,
The prices I come up with are Transmission approx $2.800 and around 12 Hrs labour. I would first get a test and report on your transmission first, and it it is deemed to beyond reasonable repair, go get a few quotes on this job as well, my price is from Mitchell 1 data base and this may vary depending on your location.
Mark (mhpautos)
ZEMORZEMOR
  • 486 POSTS
  • 1996 HONDA ACCORD
  • 232,000 MILES
The splines of the differential where the axles goes in have a lot of play. Is it normal if not what should I replace the transmission its a BOYA. I have a 96 Honda accord 2.2 liters
CARADIODOC
  • 33,743 POSTS
What's a BOYA? Some play is normal in the inner cv joint. The housing is held in the transmission with an internal spring. If you can slide that joint in and out an inch or two very easily, that's when you have a problem. It should slide in smoothly under hard hand pressure, then spring back out by itself.
ZEMORZEMOR
  • 486 POSTS
I could not understand what did you say. BOYA is what the transmission is called. When I put my finger inside the differential where the axle goes in the splines of the differential moves a lot.
CARADIODOC
  • 33,743 POSTS
Was the half-shaft causing a problem? Why did you remove it? I suspect you're feeling normal movement in the small gears that are part of the differential. Those are what are splined to engage the half-shaft.
ZEMORZEMOR
  • 486 POSTS
Ok
few days ago I saw transmission fluid on the drive way it came from the passenger side drive shaft. I took off the passenger shaft and I saw wear marks on the end of the drive shaft where it goes inside the differential. So somebody told me its the bearing because the spline of the differential has a lot of play
