1988 Honda Accord cooling fans not shutting off
HONDASTUFF
  • 1988 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 253,000 MILES
I have a 1988 Honda Accord LXI. The cooling fans operate fine during driving and when the A/C is on, but the fan dedicated to the engine does not shut off after the car is shut off. It runs until the battery is drained.
Can you direct me to the relay location, timing sensor or cooling senors that might be causing me problems?
Do you
have the same problem?
Friday, August 8th, 2008 AT 10:55 AM
KHLOW2008
  • EXPERT
Hi hondastuff,
Most probably the relay is faulty. It is located in the fuse box under hood.
Pull out the relay and the fan should stop.
Sunday, August 10th, 2008 AT 3:41 AM
Recommended Guides
