Fuel pump reset?
MIKD2525
  • 1999 GMC JIMMY
  • 6 CYL
  • 4WD
  • 15,900 MILES
I need to know were the fuel pump reset button, or the pump test wire, I have did some research and found that there is a test wire somewhere by the fuse box, but I can not find it, the truck ran good untill last week when the fuel pump stopped working, I replaced it and it is still not working, new relay, I ran a hot wire to pump and pump works, even the old one, but no power at the harness, the harness plugs up good, it is not loose or burnt. I am lost can you please help me. Thanx mike d.
Sunday, October 18th, 2009 AT 10:38 PM
There's no reset button-Did ypou check the ECM B fuse 20amp. The test connector is in the underhood fuse block
Thursday, December 27th, 2018 AT 8:32 PM
MOCERT1
  • 1997 GMC JIMMY
  • 6 CYL
  • 4WD
  • 16,000 MILES
No power to new fuel pump, fuses are good, relay good, car turns over, Is there a shut off switch in case of an accident that could be bad and if so, where is it located? Or could it just be the computer? If it would be the computer, what else should we expect to not to working?
Tuesday, July 21st, 2020 AT 5:09 PM (Merged)
The fuel pump will come on for only 2secs when you turn the key On. Power the gray wire at the fuel pump and see if it'll come on
2CP-ARCHIVES
  • 4,540 POSTS
  • 1995 GMC JIMMY
  • 90,000 MILES
Where is the switch located to reset the fuel pump and what do you need to do to reset it?
CARADIODOC
  • 33,761 POSTS
This vehicle does not have a fuel cutoff switch. There is a fuel pump relay though here is the location below and a guide to help test it.
JAMIE PASSWATER
  • 1992 GMC JIMMY
Electrical problem
1992 GMC Jimmy 6 cyl Four Wheel Drive Automatic
were is fuel pump saftey cut off switch
There's is no fuel safety cut off switch for your vehicle.
JMURRAY3585
  • 6 POSTS
Does a 1992 GMC Suburban have a reset button?
Saturday, April 3rd, 2021 AT 7:56 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
To answer your question, No, there is no fuel inertia switch on your Suburban. If you can provide any symptoms would be happy to help diagnose. Hope this helps and thanks for using 2CarPros.
Sunday, April 4th, 2021 AT 8:53 PM
JMURRAY3585
  • 6 POSTS
The suburban is getting fire but fuel pump isn't working and it new the reason why I know is because put gas in carburetor and it fired right up and already replaced almost everything on it.
Monday, April 5th, 2021 AT 5:53 AM
DANNY L
  • 5,648 POSTS
Hello again.
Have you checked the fuel pump relay? Here is a tutorial showing how to test a relay:
I've attached pictures below on how to remove and replace the fuel pump relay and its location. Hope this helps and thanks for using 2CarPros.
Danny-
Monday, April 5th, 2021 AT 8:31 PM
JMURRAY3585
  • 6 POSTS
Already did that and it keeps on catching on fire. It's like the fuel pump isn't getting no power.
Wednesday, April 7th, 2021 AT 1:29 AM
STEVE W.
  • 13,041 POSTS
If you mean the relay is burning up then it is likely that the pump itself has failed or the harness is shorted and dumping a lot of current through the relay. To test for that you would need to drop the tank and unplug the pump, if it still has a problem then you will need to trace the harness looking for damage or corrosion.
Wednesday, April 7th, 2021 AT 4:01 PM
DANNY L
  • 5,648 POSTS
Hello again.
I agree on checking the fuel pump harness. It might have a shorted wire somewhere. I've attached a fuel system wiring diagram below for you. I've curt the pictures in half so you can view larger. Let us know if you have any further questions on this issue after you test the wiring. Hope this helps and thanks again for using 2CarPros.
Danny-
Wednesday, April 7th, 2021 AT 8:39 PM
