I have a 2003 Windstar that reports "Liftgate Ajar" even when close, where is and how can I replace the sensor?
Monday, November 29th, 2010 AT 12:13 AM
CARADIODOC
MECHANIC
I'm told the switch is built into the latch, and I've heard they cause a lot of trouble. Spray the latch first with WD-40 to see if that will unstick it.
Caradiodoc
SPONSORED LINKS
Monday, November 29th, 2010 AT 12:27 AM
COLUCP
MEMBER
2002 FORD WINDSTAR
V6
AUTOMATIC
127,000 MILES
I need to replace the latch guard (the part with the Ford emblem) because the holders for both license plate lights are both broken so they won't hold bulbs anymore. I removed the liftgate inner handle along with a screw on both outer edges of the trim (one on each side). I can't figure out how to remove the trim. Does it slide out of place or does it just pop out of slots it is fitted into? I'm trying not to force it so I don't break it. This is for a 2002 Ford Windstar minivan. If anyone has pictures or something that I can download and use for reference, I would greatly appreciate it. Help!
Sunday, April 26th, 2020 AT 11:26 AM
(Merged)
HMAC300
MECHANIC
We don't show anything for that part take the panel off the inside of liftgate then you can get a better view some may just be on with two way tape. See pics.
Images (Click to make bigger)
(Merged)
COLUCP
MEMBER
I stuck a flat head screwdriver between the trim and the metal frame between where the handle screws were (before I removed them). I can peer inside and I see a plastic point that seems to just fit into a grove or hole in the metal frame. When I try to move the screwdriver to either side and further to the left or right, I don't have any give on the plastic trim so I don't know if there's another plastic point like I just described or if there's some sort of hook I have to undo by sliding a certain way. I could just pull outward but I'm afraid that I'll tear any hook and break it. It's my last option so I wanted to see if anyone has any ideas before I go to that. I looked at the pictures you posted and I removed of the screws as indicated. I just don't know what is holding the trim in place. There's no give so I can't slide it. Any further info before I resort to prying it off with a flat head screwdriver?
(Merged)
HMAC300
MECHANIC
They are straight in clips gently pry straight up and off they should come undone.
SPONSORED LINKS
(Merged)
RDEMETROS
MEMBER
1 POST
2002 FORD WINDSTAR
6 CYL
2WD
AUTOMATIC
111,109 MILES
Rear lift gate stop working. Latch has no tension on when squeezed. All electric locks works.
(Merged)
MECHANIC
Hi:
If you are refering to the handle / latch either the linkage has fallen off or it has broken. You will need to remove the door panel to access the latch assembly. It is a tight job, but doable.
