1995 Ford Windstar front windows not working
JAMBOSQUEST
  • 1995 FORD WINDSTAR
Electrical problem
1995 Ford Windstar 6 cyl Automatic
Hi I have a ford windstar 1995 my electric windows were working yesterday but when I tryed to attach the inside light my windows stopped working and my light dose not work ither have you any suggestions or diagrams I think I may have blown a fuse but I have no way of knowing which fuse dose what no manual
Do you
have the same problem?
Monday, August 18th, 2008 AT 11:31 PM
BLACKOP555
  • EXPERT
Fuse 17 I believe is the one.
You should check all fuses while your at it, get a test light and with the key on, check for voltage on the metal tabs located at the top of the fuse. If you find one that lights on one side and not the other, fuse is blown.
Tuesday, August 19th, 2008 AT 9:27 AM
Recommended Guides
