HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Climate Control
Heater
2001 Ford Taurus heater
DSROSE30
MEMBER
2001 FORD TAURUS
6 CYL
FWD
AUTOMATIC
85,000 MILES
Heater only blows slightly warm air. Engine coolant is full. Can u tell me whats wrong?
Thursday, January 31st, 2008 AT 4:59 PM
BLACKOP555
MECHANIC
Feel both heater core hoses directly at the fire wall, is one hot and one significantly cooler or are both hot?
Thursday, January 31st, 2008 AT 7:21 PM
Please
login
or
register
to post a reply.
Related Heater Content
Stuck On Heater?
This Problem Started Yesterday., When You Turn On A/c, You Can Hear Compresor Activating, I Thought Maybe It Lacked Freon, And Added 33...
Asked by
Robert Williams
4 IMAGES
2000
FORD TAURUS
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
1999 Ford Taurus Running Without The Heater:
Heater Problem 1999 Ford Taurus 6 Cyl Front Wheel Drive 189000 Miles First Off, Thanks For The Info On The Thermostat/overheating...
Asked by
pharmguy2
1999
FORD TAURUS
Heater Only Works On High
Heater Only Worked On High. I Put A New Resistor In As Suggested And The Heater Worked Fine For About A Week And Then It Went Back To...
Asked by
schaeferboy
2002
FORD TAURUS
2004 Ford Taurus Heater
The Car Runs Just Fine, The Engine Sound Good Up Until The Heater Or Air Conditioner Is Turned On. After Turning The Heater Or Air...
Asked by
beram
1 ANSWER
2004
FORD TAURUS
Heater I Get A Short Blast Of Warm Air And Then It...
I Have A 1998 Ford Taurus With 135,000 Miles. It Has Been A Good Vehicle, But I Have Run Into A Problem I Can't Solve And Neither Can...
Asked by
Buzz13
1 ANSWER
1998
FORD TAURUS
VIEW MORE
Heater Not Working
Heater Not Working
Heater Hose Replacement
