1998 Ford Taurus car wont start no power to spark plugs
JPASTRE
  • 1998 FORD TAURUS
  • 6 CYL
  • FWD
  • 159,000 MILES
Changed out the ignition coil last night and plugs back in correct order/placement. Still not starting. He also checked to fuses in the engine compartment with a tester and all looks good. He feels the next thing to check is the crank shaft sensor, but he cant get to that for a few days. What is your advice on what else to possibly check? Thank you. Jennifer
Tuesday, April 6th, 2010 AT 11:51 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, February 17th, 2017 AT 2:56 PM
