1996 Ford Taurus
GARY MILLER
  • 1996 FORD TAURUS
1996 Ford Taurus
I have 1996 ford taurus, We parked it last year and it ran fine, But it will not start now has a new fuel pump
will only turn over. We did check the kill switch. Could the kill switch be bad. If so how would we no. We can spray starter flud in it and it will start until the starter flud is gone
Thursday, April 17th, 2008 AT 1:12 PM
MERLIN2021
  • 17,250 POSTS
If it has a security system, what is the light on the dash doing when it's cranking?
Thursday, April 17th, 2008 AT 1:20 PM
MERLIN2021
  • 17,250 POSTS
Youll have to test the connector at the pump, if it has power, then check ignition switch, switch activates injectors when cranking. If no power at the connector, check the wiring, mine developed a break under the left front inner fender.
Tuesday, April 22nd, 2008 AT 2:31 PM
