1994 Ford Taurus Starting problem.
JOANNAL
  • 1994 FORD TAURUS
Electrical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
I can start my car right up the first time, but after I drive it around for awhile then turn my car off, if I try to start it again it struggles. If I turn it off once more then try to start again it wont start at all and acts like it's a dead battery. If I wait a long time and try to start again, it will, once it's cooled down.
The starter has been replaced, the battery is brand new.
Sunday, August 1st, 2010 AT 6:42 PM
Check and test the starter relay, transmission range switch and ignition switch make sure the battery and connections are good
Thursday, March 16th, 2017 AT 12:43 PM
JOANNAL
Thank you very much. I told my dad, and he said that he would do that and that it was very good advice. Hopefully it works out!
Thank you very much. Lets hope he finds the problem.
