2002 Ford Ranger Air Bag Sensors & door ajar
YCUL
  • 2002 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 100,000 MILES
Hi! Where are the air bag sensors located.
The door Ajar light stays on. There is a door and a half. Can tell how to fix these troubled areas? The manuel I bought does not tell me how to remedy these problems. Also how do you get the door panel off on the half door. I see no serews that would allow me to take it off. Thank you. Bill
Do you
have the same problem?
Saturday, February 6th, 2010 AT 3:18 PM
SERVICE WRITER
  • EXPERT
I will update this in a minute regarding the panel.
For the door ajar problem. Get a thin lubricant and some brake clean. Clean the door latches with the cleaner and then soak them with the penetrant...wd-40 would work. Open and close the doors several to 20 times each and see if that resolves it first. If not there is a latch that may need replaced.
On the air bag:
http://www.2carpros.com/forum/automotive_pictures/30961_zairbag2_1.jpg
http://www.2carpros.com/forum/automotive_pictures/30961_zairbag_1.jpg
Sunday, February 7th, 2010 AT 7:11 AM
SERVICE WRITER
  • EXPERT
http://www.2carpros.com/forum/automotive_pictures/30961_zpanel_1.jpg
http://www.2carpros.com/forum/automotive_pictures/30961_z78_1.jpg
http://www.2carpros.com/forum/automotive_pictures/30961_z79_1.jpg
http://www.2carpros.com/forum/automotive_pictures/30961_z80_1.jpg
http://www.2carpros.com/forum/automotive_pictures/30961_z81_1.jpg
http://www.2carpros.com/forum/automotive_pictures/30961_z82_1.jpg
Sunday, February 7th, 2010 AT 7:25 AM
Recommended Guides
