Timing belt marks diagram
HAIRBALL55
  • 1999 FORD RANGER
  • 4 CYL
  • MANUAL
  • 150,000 MILES
Timing belt diagram ford 2.5 please.
Saturday, January 15th, 2011 AT 8:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a guide and a diagrams below to show you the camshaft timing look at the bottom of the guide.
https://www.2carpros.com/diagrams/ford/ranger/1999
Thursday, February 24th, 2011 AT 7:54 PM
JOSHUA83CARL
  • 1999 FORD RANGER
I have recently changed the timing belt on my Ranger. The camshaft gear had a diamond and a triangle that lined up, the gear (I believe is an emissions pump) had a triangle that lined up, But the crankshaft gear only had a dot on it and no dots to line up. So I found top-dead-center on a compression stroke and the dot on the crankshaft lined up with a notch. I assume this is correct timing. After puting everything back on the truck started right up. But, it had a very high idle, I drove it down the road and back and put a timing light on it, the timing then kicked down to a low idle but was not the correct idle. The timing light showed the mark on the Harmonic balancer bounce from 30 deg. And up. The truck is supposed to be timed at 10 deg. What could be causing this problem? How can I fix it if the truck doenst have adjustable timing? Thank You
Wednesday, November 11th, 2020 AT 6:19 PM (Merged)
NOS
  • 320 POSTS
Here are the camshaft timing marks so you can double check them
It sounds like the computer needs to relearn just drive it for a few days see what happens.
Wednesday, November 11th, 2020 AT 6:20 PM (Merged)
JOSHUA83CARL
Thanks for the guide I double checked the timing belt it was off one tooth everything is great now thanks for your help. I love this site.
NOS
  • 320 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
BARBERA
  • 1999 FORD RANGER
  • 115,500 MILES
The timing belt on my truck and was repaired the mechanic is telling me that after I drive it approx 150 to 200 miles that I need to bring it back for adjustments. I have had the timiing belt serviced before and have never had this request. Just curious if this is a valid service.
KHLOW2008
  • 41,814 POSTS
Never heard of beltings requiring adjustment after a short drive.
  • 31,937 POSTS
No this is not required, I have never seen a timing belt that requires re tensioning after installation.
FIXITMR
  • 9,990 POSTS
Almost motors with timing belts have automatic tensioners. The few that dont would need to be rechecked for proper tension after short 'break in' period. This can be as simple as removing upper plastic cover and checking for tension by feel/sight.
JAMESDEAN054
  • 1999 FORD RANGER
  • 4 CYL
  • MANUAL
  • 95,000 MILES
I am sure we have lined the appropiate marks as per manual and the truck doesn't even fire, am I missing something? Thank you my email is jamesdean054@gmail. Com
BLUELIGHTNIN6
  • 16,542 POSTS
On this truck there is a diamond and a triangle stamped into both gears be sure to clean them off and make sure you are using the triangle for the cam and the diamond on the oil pump. Otherwise you have no compression.
HILTZYY
  • 1999 FORD RANGER
  • 4 CYL
  • 132,000 MILES
Hello just had timing belt replaced 2 weeks ago. Seemed to be ok now it bucks a little and stalles once in a while. Is it the timinf or mabey fuel filter plese help dont want my wife to break down also ck. Engine ligh comes on and off every so often im disabled with a brain injury I cant donate at this time
BLUELIGHTNIN6
  • 16,542 POSTS
Was it stalling prior to timing belt replacement? Since engine light is coming on, have the codes scanned to help pinpoint the culprit. Most local auto part stores will do this for free.
HILTZYY
Did not stall before but ck engine light wood go on and off for a while. Always got a legal sticker passed everything but engine light was always off not sure what to do thank u have not gotten it scanned for codes.
BLUELIGHTNIN6
  • 16,542 POSTS
Engine bucking is usually caused by misfires. Check the spark plugs to ensure they are getting healthy blue/white spark. If they are, test the fuel pressure to ensure it is up to specs.
