1994 Ford Ranger spark plugs
RODS 1942`
  • 1994 FORD RANGER
Electrical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
what is the best way to get the plugs out on the left hand side of the engine
Do you
have the same problem?
Tuesday, November 17th, 2009 AT 6:33 PM
RACEFAN966
  • EXPERT
Best I can tell with out on infront of me is to remove the plug wires and use a swivle socket with an extention and remove them. If you can include a pic and I will look to see if you can remove anything to make it easier.
Wednesday, November 18th, 2009 AT 10:30 AM
DHUDACEK
The Manual suggests to remove the exhaust manifold. A week ago, when I replaced these, I did NOT remove the manifold. I replaced the plugs in question with a couple of socket extensions however it was not easy. Getting the new plugs back in was not easy either. To get the plugs back in I used some rubber tubing, (I believe it was 3/8 inch i.D. Tubing) and inserted the spark plug firmly into the tubing so it held the plug as I lowered it into place. I was able to get it to turn a couple of times, so that I knew it wasn't cross-threaded, then pulled the rubber tubing off and finishing tightening the plug with the plug socket and extensions. Getting the plug wire back on was also difficult as I do not have a 'plug wire puller', which would have came in handy. I put a tiny bit of vasaline on the part of the plug that is 'grabbed' by the plug wire and worked it on and off a few times prior to putting into it's hole, in order to get the plug wire to go on more easily when it came time to push it on.
Wednesday, November 18th, 2009 AT 12:34 PM
DHUDACEK
1994 Ford Ranger 4cyl 2wheel drive, spark plug manual and pics.
http://www.2carpros.com/forum/automotive_pictures/436759_DSCF3878_2.jpg
http://www.2carpros.com/forum/automotive_pictures/436759_img177_2.jpg
http://www.2carpros.com/forum/automotive_pictures/436759_img178_2.jpg
Wednesday, November 18th, 2009 AT 1:13 PM
Recommended Guides
