2007 Ford F-150 Idle speed fuel clog
SKIYRYDER
  • 2007 FORD F-150
  • V8
  • 4WD
  • 64,000 MILES
When I stop at a light or stop sign the engine RPMs drop to 0 and the truck dies. Fuel consumption is also higher. Is this from bad gas, the fuel filter, or something in the computer system that controls fuel into the engine?
Do you
have the same problem?
Thursday, March 5th, 2009 AT 9:51 AM
RACEFAN966
  • EXPERT
Ok is the check engine light on? Get back to me
Thursday, March 5th, 2009 AT 10:30 AM
DAVE H
  • EXPERT
Hello. Thanks for the donation. Much appreciated
Is the CEL (check engine light) showing on the dash display?. This fault could be due to the IAC or MAF sensors or other control sensors? The vehicle should still be under warranty? Have fords check this out for you ! Hope this helps. Let me know
Thursday, March 5th, 2009 AT 10:31 AM
Recommended Guides
