1996 Ford F-150
JOEVALLEZ
  • 1996 FORD F-150
  • 6 CYL
  • 148,000 MILES
How can I disconnect the rear gas tank. Thanks.
Sunday, February 3rd, 2008 AT 12:10 PM
MIKE H R
  • 3,094 POSTS
Disconnect in what way. You can take the fuse out, if you want to disconnect the lines they are spring lock couplings with safety clips, pry them off with a small screwdriver inside there are male and female fittings. There is a special tool out there that when used releases the female coupling. For safety make sure you have the power shut off to the fuel pump!
Sunday, February 3rd, 2008 AT 12:30 PM
