1995 Ford F-150 engine pulses
SMOKER537
  • 1995 FORD F-150
  • V8
  • 4WD
  • 96,000 MILES
When I stop at red light or stop sign the engine pulse, or surges feels like the truck wants to move what could be the problem. Thanks, scott
Do you
have the same problem?
Monday, May 19th, 2008 AT 4:28 PM
MERLIN2021
  • EXPERT
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs!
Monday, May 19th, 2008 AT 4:41 PM
Recommended Guides
