1991 Ford F-150 oil leaking
MACDZUL
  • 1991 FORD F-150
  • V8
  • 4WD
  • 139,000 MILES
Just bought this truck was running fine and all of a sudden started leaking oil from behind the oil pan when running. When not running it doesn't leak.I'm hoping its not a rear seal
updated 4/9/10
It might just be coming from the intake and running down. How would I know for sure?
Sunday, March 28th, 2010 AT 10:56 AM
  • 110,194 POSTS
That is all that is there to leak, the rear seal. However, make sure it isn't coming from the rear of the intake and running down.
Let me know what you find.
Monday, March 29th, 2010 AT 7:27 AM
  • 110,194 POSTS
You have two choices. One is to simply clean the rear of the engine really well with an engine degreaser, run the truck and see if you can tell where the leak is coming from.
Also, they make a dye you can put into the oil. After it is in, run the truck and then using a black light, you will see where the leak is coming from because the dye will glow.
Friday, April 9th, 2010 AT 7:43 PM
