HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Oil Leak
1991 Ford F-150 oil leak
HOPPER 123
MEMBER
1991 FORD F-150
V8
4WD
AUTOMATIC
94,000 MILES
How costly is it to replace the rear oil seal?
Tuesday, January 26th, 2010 AT 6:15 PM
OBXAUTOMEDIC
MECHANIC
In order to replace the rear main seal the tranny has to come outand the flywheel has to be removed. And with it being a 4x4 the cost could be $700 - $1,000 maybe more depending on labor rate in your area.
Tuesday, January 26th, 2010 AT 6:23 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
1991 Ford F150 Oil Leaking
Just Bought This Truck Was Running Fine And All Of A Sudden Started Leaking Oil From Behind The Oil Pan When Running. When Not Running It...
Asked by
macdzul
1991
FORD F-150
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
1993 Ford F150 Oil Leak On Oil Pan
Hello, My Name Is Paul, Truck Has A 302, Truckis On Jack Stands, Engine Is Raised, Motor Mounts Are Loose, Exhaust Is Out Of Way, Inches...
Asked by
paulsdogs
1993
FORD F-150
Motor Oil Leak
Ford F150,2005 41k, V6 Not So Much A Repair Question But More Of How Much Is This Gonna Cost Question. The Oil Gauge On The Truck Was...
Asked by
corbey97
FORD F-150
1997 Ford F-150 Oil Leak
I Have An Oil Leak Coming From What I Believe Is My Timing Chain Cover. I Noticed The Tensioner Is Rubbing Against It And Has Burnt A Hole...
Asked by
camopaint0707
1997
FORD F-150
Oil Leak
I Have A Leaking Rear Differental, If I Put Off Repair What Is The Danger?
Asked by
sickman63
7 IMAGES
2001
FORD F-150
VIEW MORE
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Cylinder Head Gasket Blown Symptoms
