No Reverse?
SRW35
  • 1997 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 139,000 MILES
Hi! I have a 97 explorer sport with 139k miles on it. Recently the reverse just stopped working in it. Then, just last week I was stopped at a red light and hit the gas pedal and it wouldn't drive forward. We've put a brand new water & fuel pump into, and just don't want to get a new car. What do you think could be wrong with it?
Sunday, November 7th, 2010 AT 6:22 PM
  • 108,192 POSTS
Will it move if you shift the transmission in 1 or 2? If you do not have reverse, you have an internal failure in the unit.
It will have to be removed and inspected for the failure.
Do you have any codes set? It sounds like you may have a gear range sensor that is out but to be sure lets run down these guides to help us fix it.
When was the last time you changed the fluid and filter?
Monday, November 8th, 2010 AT 10:27 AM
SRW35
The car will go forward in 2nd gear, but will not go into reverse nor will it go forward in first gear
Tuesday, November 9th, 2010 AT 2:13 PM
  • 108,192 POSTS
It sounds like a broken band. I hate to say it, but I beileve it needs removed and taken apart to identify where the problem is coming from.
Wednesday, November 10th, 2010 AT 10:11 AM
RAMCCULLOUGH311
  • 6 CYL
  • 4WD
  • 219,000 MILES
When I put the truck in forward or reverse and press the gas the rpms shoot up and the truck dosent move. Also when shifting from second to third you have to let off the gas and then it will shift.
Tuesday, December 22nd, 2020 AT 8:58 AM (Merged)
  • 31,938 POSTS
Hi there,
This is an internal problem with the transmission, I would be thinking that it is a fluid pressure related problem, a scan may shed some light onto the issue, I would get this done by a trans specialist as they will be aware of particular problems that may be common with this transmission, start here.
Mark (mhpautos)
RAMCCULLOUGH311
We have had it put on a computer and 5 different codes popped up. I have checked the fluid in it and it was a little low so I topped it off but it did not fix the problem!
  • 31,938 POSTS
What were the codes you got?
Mark (mhpautos)
SHARON NESMITH
1997 Ford Explorer Two Wheel Drive 6900.0 miles
I replaced the motor and now it will not move when I put it into reverse or drive.
  • 108,192 POSTS
Is it the same transmission? Are you sure the fluid is full? Are you sure the cooling lines correctly attached? Did the torque converter slip easily into the front pump and is it bolted to the flywheel? Is the linkage attached correctly?
MMJA1011
Transmission problem
1997 Ford Explorer Four Wheel Drive Automatic 182000 miles
I have a '97 ford explorer xlt with a little over 180,000 miles on it. About 5 or 6 months ago it started grinding slightly but has gotten worse over time. It grinds when I put the car in reverse, when I go above 50 miles per hour, and also especially on hills. I've been told the transmission needs replaced but before I can do that I have to figure out the exact one I need. The only thing I don't know is if it needs a transmission with or without an overdrive drum sensor.
MERLIN2021
  • 17,250 POSTS
Two trannys used in these are e4od and 4r70w here are the pan gaskets for both, this will tell you which tranny you have.
https://www.2carpros.com/forum/automotive_pictures/62217_e4od_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_4r70w_1.jpg
JAMES W.
  • 2,395 POSTS
Just a question out of the blue. Are you sure it's not your transfer case?
MASTERK
  • 6 CYL
  • 4WD
  • 165,000 MILES
I have a 97 explorer that drives perfectly fine in all forward gears but refuses to go in reverse. Initially I thought in was an internal transmission problem but now think it may be linkage. I recently noticed that it also won't move forward or backward while in neutral with the engine running or not. Yet it stills drives forward. Also the shifter needle nevers quite points to the gear I put it in. It's more like in between. Anyone have experience with this or suggestions.
  • 31,938 POSTS
Hi there,
You best get your mechanic to inspect the linkage adjustment. But I feel it may be a transmission problem, as normally when the adjustment is out, and you select through the gears you will normally still be able to pick up all the gears, (feel it engage as you shift through) have the adjustments check first as a precaution, as you don't want them removing the box for no reason.
Mark (mhpautos)
DOLLAZ
  • 8 POSTS
  • 1996 FORD EXPLORER
  • 5.0L
  • V8
  • 200,000 MILES
Transmission will go in reverse but when in drive it will not move. Can changing the fluid and filter solve this issue?
  • 52,797 POSTS
Good evening.
I doubt it. When the filter is clogged, it usually affects all gears.
It sounds like the forward clutch pack has failed internally.
Tuesday, December 22nd, 2020 AT 8:59 AM (Merged)
DOLLAZ
  • 8 POSTS
So only solution is new transmission or rebuild?
  • 52,797 POSTS
Correct, or a used one for replacement.
DOLLAZ
  • 8 POSTS
Okay, thanks for the insight.
  • 52,797 POSTS
You are welcome.
Always glad to help.
