Oil gauge is acting funny, it will be fine and then sometimes it just goes to nothing but the motor sounds and runs fine.
Monday, January 25th, 2010 AT 4:13 PM
BLUELIGHTNIN6
MECHANIC
The oil pressure switch at left side of engine block. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Monday, January 25th, 2010 AT 4:14 PM
2CP-ARCHIVES
MEMBER
2002 FORD EXPLORER
6 CYL
2WD
AUTOMATIC
45,000 MILES
2002 Ford Explorer mileage: 45,000. Where is the oil sending unit located on this model?
Thursday, March 7th, 2019 AT 3:22 PM
(Merged)
2CP-ARCHIVES
MEMBER
The oil pressure-sending unit should be next to the oil filter.
(Merged)
LINDA_COLE03
MEMBER
1996 FORD EXPLORER
170,000 MILES
I am looking for a detail diagram as to where I can locate the oil pressure switch, can you help me with this. It is a 6 cylinder motor. I bought the part because I am get erratic readings on the gauge now I have no idea as to where it goes, is it next to the oil filter and if so, where?
(Merged)
MECHANIC
What liter engine?
SPONSORED LINKS
(Merged)
FIXITMR
MECHANIC
Is that a 4.0?
Thursday, March 7th, 2019 AT 3:23 PM
(Merged)
LINDA_COLE03
MEMBER
I do believe it is a 4.0 engine
(Merged)
FIXITMR
MECHANIC
Ok all I can find right now is this. It's right by/behind power steering pump. Hope it helps
Image (Click to make bigger)
(Merged)
FIXITMR
MECHANIC
Found another.
(Merged)
BREADMANJOHN
MEMBER
1 POST
1999 FORD EXPLORER
98,000 MILES
Oil pressure sticks with cold start, after a few seconds it jumps up to normal.
(Merged)
DOCFIXIT
MECHANIC
Next to power steering pump in block
(Merged)
FIXITMR
MECHANIC
If you see blank image(thumb)click anyway it should pop. My internet glitched on me.
SPONSORED LINKS
(Merged)
JDL
MECHANIC
It should be next to the power steering pump.
(Merged)
LINDA_COLE03
MEMBER
Thank you very much. I do believe this is going to help me find it. I appreciate your assistance.
(Merged)
RIVERMIKERAT
MECHANIC
Linda, were the images helpful? Did you get the oil pressure sending unit changed out?
(Merged)
MEONEIL
MEMBER
1 POST
2001 FORD EXPLORER
Engine problem
2001 Ford Explorer 6 cyl Four Wheel Drive Automatic 100K miles
Can you tell me where the oil pressure sending unit is located?
(Merged)
MECHANIC
The engine oil pressure switch is located on the engine next to the power steering pump-see below
(Merged)
STUKNBAMA
MEMBER
FORD EXPLORER
Where is the oil sending unit on a 2001 Ford Explorer with the v6 OHC?
I know it needs replacing, but can't locate it.
Thanks in advance
(Merged)
STUKNBAMA
MEMBER
ANYONE out there?
(Merged)
STUKNBAMA
MEMBER
Does anyone have any idea on where this is located?
