I need a firing order diagram. I have a v6 4.0 engine
Saturday, October 27th, 2012 AT 8:00 PM
HMAC300
MECHANIC
Here is the engine spark plug firing order.
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Image (Click to make bigger)
SPONSORED LINKS
Saturday, October 27th, 2012 AT 11:24 PM
JESSICA SMITH
MEMBER
1 POST
2005 FORD MUSTANG
4.0L
6 CYL
2WD
MANUAL
100,000 MILES
My boyfriend did a tune up on my car and now it wont start. I went out and moved a couple wires around and it started up but ran rough. And could smell my screaming dreaming coil pack start to burn. So I am convinced that it is the wires in the wrong order. And hopefully it hasn't messed up my coil pack.
Wednesday, October 14th, 2020 AT 12:59 PM
(Merged)
MECHANIC
Good evening,
Can you post a picture of what you see at the coil?
Firing order. 1-4-2-5-3-6
(Merged)
PACHYAUTO63
MEMBER
2002 FORD MUSTANG
3.8L
6 CYL
2WD
AUTOMATIC
125,000 MILES
Can you give me a firing order diagram for this vehicle?
(Merged)
STEVE W.
MECHANIC
The firing order is 1-4-2-5-3-6. The right hand diagram is the 3.8s cylinder layout as viewed from the front of the vehicle. The lower block is the ignition coil layout for the wires. Hope that helps.
SPONSORED LINKS
(Merged)
AWHITWORTH77
MEMBER
1998 FORD MUSTANG
3.8L
6 CYL
120,000 MILES
I misplaced my plug wires I need to know how to rewire it.
(Merged)
MECHANIC
I attached the cylinder layout and coil pack. The firing order for this engine is
1-4-2-5-3-6
Let us know if you need more info. Thanks
Images (Click to make bigger)
(Merged)
AWHITWORTH77
MEMBER
1998 FORD MUSTANG
3.8L
6 CYL
2WD
AUTOMATIC
125,000 MILES
How do I do the wiring on the coil pack for the timing? I misplaced my wires when changing the plugs.
(Merged)
MECHANIC
No problem.
I attached pics below. The first one shows the firing order and cylinder location. Pic 2 shows the coil and which connector goes to which cylinder. Pic 3 is a general overview of replacing the wires.
(Merged)
INFANTRYVETERAN
MEMBER
1 POST
1998 FORD MUSTANG
6 CYL
2WD
AUTOMATIC
171,000 MILES
I changed my spark plugs and my wires. Doing one at time to insure I did not mess up the firing order. No my car back fires and shakes alot. What have I done wrong?
(Merged)
DAVE H
MECHANIC
Check all the plugs are tightened correctly .. double check they are in the correct order this diagram is of a 3.8L
(Merged)
