Engine stalls at idle?
MAMBOBD
  • 1999 TOYOTA COROLLA
  • 6 CYL
  • 85,000 MILES
My cars engine stalls whenever I try to drive in reverse
Sunday, January 31st, 2010 AT 12:55 AM
MMPRINCE4000
  • 8,548 POSTS
Other than replacing the IAC (idle air control valve), this could be a trans problem. Also check the motor mounts for excessive engine movement when reverse is selected. This sounds like you have a vacuum leak, dirty throttle bore or the IAC motor is not working but to be sure lets check out these guides to help us fix it.
https://www.2carpros.com/articles/stall-at-idle
and
and
Sunday, January 31st, 2010 AT 8:27 AM
MARIOC68
  • 120 POSTS
  • 1996 TOYOTA COROLLA
  • 300,000 MILES
Hi, my car goes off when the brakes come on and I start a gear. Which may be?
Friday, January 22nd, 2021 AT 10:55 AM (Merged)
  • 31,937 POSTS
So when you have the brakes on, the engine stops as if you turn the key or it falters and stalls? If it is the latter, you will probably have a faulty brake booster.
MARIOC68
  • 120 POSTS
Hi.
The engine idle falters and stalls. I have noticed that booster of my car has no check valve brake. Can it be the origin of the problem?
  • 31,937 POSTS
The check valve is plugged into the booster, see pic and look at your booster.
MARIOC68
  • 120 POSTS
The model of my vehicle the valve is not coupled to the booster. It is between the booster hose and the intake manifold, as seen in the images(see 44730).
  • 31,937 POSTS
It should be easy to replace, have you done that yet?
MARIOC68
  • 120 POSTS
I got one. Missing install. Then verify your performance.
MARIOC68
  • 120 POSTS
  • 4 CYL
  • 200,000 MILES
The engine of my car is turned off when stepping on the brake. The vehicle has an automatic transmission.
HMAC300
  • 48,601 POSTS
Try cleaning throttle plate on both sides and IAC hole with choke cleaner.
MARIOC68
  • 120 POSTS
Already had done, but even follows the problem.
HMAC300
  • 48,601 POSTS
Okay, well not knowing that is the first thing I recommend. check fuel pressure with a gauge may be low. auto parts rent gauge.
BRUCE BAKER
  • 1995 TOYOTA COROLLA
  • 1.8L
  • 4 CYL
  • 210 MILES
Then it may not start for 20 minutes.
  • 108,328 POSTS
The first thing I would think is the ignition is affected by the moisture. Do me a favor. When this happens and it won't start, check to see if there is spark to the plugs. Here is a link that shows how it's done:
If there is no spark or a weak spark, the first thing I would do is check the distributor cap to make sure it is tight and has no cracks. Also, check to see if the ignition plug wires are in good condition as well as the coil wire to the cap. Have a helper crank the vehicle and see if you notice anything sparking. If you have some down time, open the hood, start the engine, and lightly mist the areas I mentioned with water to see if it causes a stall.
Picture 1 below shows the distributor cap.
Do this and let me know what you find or if you have other questions.
The main thing that is going to affect starting or running when wet is the ignition system. So we need to pull a spark plug and check for a strong blue spark. I suspect you have an issue with the igniter or the coil itself. If you have spark but it is not strong or is even yellowish in color then most likely the secondary side of the coil is the issue so you are not getting the high voltage spark that you need.
I attached the basic info about this system. Let me know what you find with the condition of the spark when this is happening and we can go from there.
GONZA0424
Shakes or Wobbles problem
1995 Toyota Corolla Two Wheel Drive Automatic 104000 miles
The car rides fine when its going in high speeds but when its time to slow down and stop it stalls or starts to shake like it's gonna turn off. I have to put it in Neutral and pump the gas to keep it from shutting off. Please help. Thanks for your time!
Friday, January 22nd, 2021 AT 10:56 AM (Merged)
JTANGEL2662
Hey did you find out what is wrong with your toyota? I have the exact same problem.
Thanks
MMPRINCE4000
  • 8,548 POSTS
Check the Idle Air Control valve, they get dirty and can get stuck. Also check the EGR valve, they are not supposed to operate at idle/slow speed, if they open at idle, they will generally kill the engine.
Also make sure the torque convertor clutch is working properly, they engauge at 40-45mph, so you should feel the rpm's go up slightly when decelerating from 55 to 40-45, If not the TCC will kill the engine.
You can feel the TCC engauge when accelerating (smoothly) at 40-45mph. It will shift into high gear then you will feel a small "bump" when it locks up, you should also feel it disengage.
MIKECARILLO
  • 1994 TOYOTA COROLLA
I have a 1994 Corolla that just had a water pump replaced. After which the car started running with a tiny miss. After the car was warmed up I took it for a ride and and made a really horrible noise like spark ping but LOUD! It has slow acceleration as well as stalling when I come to a stop sign. Timing belt was replaced a few years ago. What can it be? It happened right after the Water pump was replaced.
Friday, January 22nd, 2021 AT 10:59 AM (Merged)
MIKE H R
  • 3,094 POSTS
Check the wires to see if there is a crossed wire, If you deid anything withe the plug wires it sounds that two spark plug wires are crossed. That would cause the misfire and ping. Just by reading your post to me that is what happened.
