2005 Dodge Neon Car stalled out in high water
INDIANARCHY
  • 2005 DODGE NEON
  • 4 CYL
  • FWD
  • 62,000 MILES
I drove into some high water on a backroad. I wasn't going too fast when I hit it. Maybe 20 mph. The engine died right away. The water was high enough that it started flooding into the floor of the car. And I'm sure a lot under the hood was flooded. The car sat there for maybe 30 minutes before I got some help and got it pushed out. Then we towed it home.
When I try and hit the ignition, it sounds like it wants to start. It's making a very loud sound. The engine seems to shake a lot when I try and start it. We checked the air-intake and the filter was wet and there were some leaves and other debris in there.
What can I do?
Friday, February 8th, 2008 AT 4:07 PM
BLACKOP555
  • 10,386 POSTS
Clean out every electrical component and relay everything, dry everything off and try a new starter, see if it works, you probaly have water shorting out a relay somewhere.
Check the fuses also.
Friday, February 8th, 2008 AT 5:41 PM
