Misfiring when engine is running?
DIANA MC
  • 2005 DODGE NEON
  • 2.0L
  • 4 CYL
  • 156,000 MILES
The car runs good when it is cold, but when it gets warmed up you will be driving and it starts cutting out like it is not getting gas.
Wednesday, December 4th, 2019 AT 8:50 AM
This could be a fuel pump cutting out but I want to clarify if the engine is completely cutting off when it get warm? If this is then it could also be a crank sensor.
Here is the guide to test the fuel pressure. I would suggest just hooking up a gauge and taping it to the windshield so you can see it when driving.
and
I attached the info about the crank sensor as well.
Wednesday, December 4th, 2019 AT 3:48 PM
MYLAURIE
  • 2005 DODGE NEON
  • 4 CYL
  • MANUAL
  • 101,945 MILES
Or if I'm going up a hill the check engine light came on. Sometimes when I'm driving 60 it runs smooth but I feel a little bit of hesitation. Other than the second gear chug it is great.
Wednesday, July 29th, 2020 AT 11:55 AM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
It sounds like the engine is misfiring under load which is typical. Here are two guides to help us fix the problem
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
DODGENWW
  • 56 POSTS
  • 2005 DODGE NEON
  • 2.0L
  • 4 CYL
  • FWD
  • 183,000 MILES
Why does my car keep throwing cylinder 1 misfire code or what could be the problem making it do this?
HMAC300
  • 48,601 POSTS
This could be anything best to have a local professional freeze frame and record it to see if it is a sensor gone bad. otherwise you will dump a bunch of money on probably good parts. You can check the fuel pressure and compression to see if that is it. auto parts rent the fuel pressure gauge
HEATHER08
  • 2004 DODGE NEON
  • 4 CYL
  • 65,000 MILES
At low idle, the car chugs and has no horsepower, and sometimes miss fires. We have changed the spark plugs many times and even with really expensive plugs with a five year warranty they died with in three months. What could be causing our car to burn though spark plugs. And how much will it cost to fix?
Wednesday, July 29th, 2020 AT 11:56 AM (Merged)
AIRSOFTSOLDRECN9
  • 348 POSTS
Are they completely black or are the electrodes burned off? If it is black the engine is too rich. Check the MAP, TPS and CTS sensors for proper functioning.
