HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine
Symptoms
Oil Leak
1998 Dodge Neon OIL LEAK AT HEAD
PHALLBERG
MEMBER
1998 DODGE NEON
Engine problem
1998 Dodge Neon 4 cyl Front Wheel Drive Automatic 70.000 miles
1998 dodge neon 70.000 miles
have you ever heard of a camshaft wearing into the head enough to make it leak on the outside?
Monday, January 14th, 2008 AT 8:18 PM
MECHANIC
Hi there,
where on the head is it leaking, can you post a picture of this?
Mark (mhpautos)
Monday, January 14th, 2008 AT 9:31 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
1998 Dodge Neon Anit Freeze And Oil Leak
My Doge Neon Started Leaking Anti Freeze Now Its Leaking Oil Too I Replaced The Oil Pan Gasket And Its Still Leaking. I Cant Find Where The...
Asked by
rifsm1
1998
DODGE NEON
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
Oil Leak Between The Oil Pan And The Main Seal
Only When The Car Is Running Leaking Oil Pretty Bad. It Looks Like It Is Leaking Between The Oil Pan In The Main Seal. Pretty Bad Oil Leak.
Asked by
aaron1967
1 ANSWER
1998
DODGE NEON
1998 Dodge Neon Oil Leak
Hi, I Have A 1998 Neon. When I Got It It Had A Small Oil Leak. It Just Dripped Here And There, Would Be Fine Between Oil Changes For About...
Asked by
Killa
1 ANSWER
1998
DODGE NEON
1998 Dodge Neon Oil Leaks
1998 Dodge Neon I Have A Oil Leak And Im Not Sure Where Its Coming From Is It Going To Cost A Arm And Leg To Fix The Leak Isnt Bad.
Asked by
poptart
1 ANSWER
1998
DODGE NEON
Have An Oil Leak, Seems To Be Sitting On Tranny, Were Could It Be Coming From
Asked by
darrell dee
1 ANSWER
1998
DODGE NEON
VIEW MORE
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Can You Fix a Head Gasket with a Sealer?
