Image (Click to make bigger)
SPONSORED LINKS
Thursday, December 9th, 2010 AT 2:14 PM
RAYMOND_LIGHTFOOT
MEMBER
1 POST
2004 DODGE DURANGO
V8
AWD
AUTOMATIC
65,000 MILES
I had recently had my oxygen sensor changed. The check engine light comes on then a day later it goes off again. A few weeks go by then the same thing happens. Go the codes checked at Auto Zone and it showed P0137 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2). Do I need to change it again or could there be another reason why this happens?
Tuesday, July 16th, 2019 AT 2:16 PM
(Merged)
DOCFIXIT
MECHANIC
Is this the same O2 you previously replaced? I ask cause there are 4 on vehicle. If it is there maybe problem with circuit and will need proper diagnosis by a Tech.
(Merged)
RON6969
MEMBER
1 POST
2001 DODGE DURANGO
V8
4WD
AUTOMATIC
150 MILES
L1 bank sensor running Lean ive changed the 02 sensor twice already and advice. Its blowing black carbon out the tail pipe and you can smell gas bad.
(Merged)
CARADIODOC
MECHANIC
Typical of a misfiring cylinder. You smell the unburned fuel, but the O2 sensor detects the unburned oxygen, not fuel. Since it says there is too much unburned oxygen, the Engine Computer commands more fuel to all of the cylinders. After that there is STILL that unburned oxygen that is detected.
SPONSORED LINKS
(Merged)
AFOAJOSHUA
MEMBER
2005 DODGE DURANGO
4.7L
V8
2WD
AUTOMATIC
I'm trying to find out the name of the colors on my o2 sensor
Tuesday, July 16th, 2019 AT 2:17 PM
(Merged)
CARADIODOC
MECHANIC
You have four oxygen sensors. The left downstream sensor is different than the other three. The original wire colors are white, white, white, and black. A lot of aftermarket replacements use white, white, gray, and black.
(Merged)
AFOAJOSHUA
MEMBER
The upstream sensor 1/1
(Merged)
JON123
MEMBER
1 POST
2005 DODGE DURANGO
V8
AWD
AUTOMATIC
99,000 MILES
How do I check circuit fuse and relay
(Merged)
MECHANIC
Hi:
You can check a fuse by checking for continunity. As far as a relay, usually there are more than one in the relay block with the same part number. Make sure they are the same and switch them.
