How do I replace the blower fan motor?
BJONES62
  • 1999 DODGE DURANGO
  • 10,000 MILES
Blower fan only works when I tap it with a hammer! I need to change it. I love this site
Monday, February 27th, 2012 AT 10:06 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,110 POSTS
Here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
This blower motor should be accessible without removing the HVAC.
Here are some diagrams (below) of the front and rear blowers and what it will be like on your car.
Cheers, Ken
Saturday, October 21st, 2017 AT 2:14 PM
JOHNTE
  • 2000 DODGE DURANGO
  • V8
  • 4WD
  • 245,000 MILES
Heater problem
2000 Dodge Durango V8 Four Wheel Drive Automatic 245000 miles
I need directions to remove old heater motor and install new motor. If you have sheet showing location and directions that would be perfect
Saturday, October 21st, 2017 AT 2:15 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
NOTE: Removal of the blower motor on these models requires that the A/C lines be disconnected. According to law, refrigerant must be captured and reused which requires the use of special equipment and training. This procedure MUST be performed by a certified MVAC technician.
1. Disconnect the battery negative cable.
2. Remove the instrument panel.
3. Recover the refrigerant. See "Note" above.
4. Disconnect the liquid line refrigerant line fitting from the evaporator inlet tube.
5. Disconnect the accumulator inlet tube.
6. Drain the cooling system.
7. Disconnect the heater hoses from the heater core tubes.
8. Remove the four nuts from the heater-A/C mounting studs on the engine compartment side of the dash panel.
9. Remove the nut that secures the heater-A/C housing mounting brace to the stud on the passenger compartment side of the dashboard.
10. Pull the housing rearward far enough for the mounting studs and evaporator condensate drain tube to clear the dash panel holes.
11. Remove the housing from the vehicle.
12. Remove the three screws that secure the motor to the housing.
13. Remove the wheel, if desired, by removing the clip from the motor shaft.
14. Installation is the reverse of removal. Note the following points:
A. When installing the wheel onto the shaft, be sure to line up the flats.
B. The ears of the retaining clip must be on the shaft flat.
C. Be sure the blower motor seal is in place.
Here's a couple exploded views of the dash and HVAC plenum that need to be removed
MACNCAT
Heater problem
I need to replace the blower motor and I wanted to know if there is anywhere that I can get an exploded view schematic of the dashboard and blower motor assembly.
  • 108,336 POSTS
Hi:
I cant find an exploded view, but if you go to:
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
It will provide the directions and it does have some of the pictures.
Let me kno if this helps.
JOHNTR250
  • 2003 DODGE DURANGO
Heater problem
2003 Dodge Durango
Blower motor will not work. I changed the fuse and changed the fuseable link and it still will not work. Any suggestions
BLUELIGHTNIN6
  • 16,542 POSTS
Test for power at the motor. If no power, test wiring for shorts. If power is present, suspect faulty motor.
BOOKER915
  • V8
  • 4WD
  • 141,000 MILES
Broken (front) heater blower control. The heater blower control for the front part of the truck started to work intermitently, then finaly packed it in totally. I need to know how to remove the control module from the dashboard and how to repair the front blower switch. Many thanks for the help.
Phil
JDL
  • 16,098 POSTS
With everything on, did you check for voltage and ground at the blower motor connector? If your saying the blower won't work? I'll look for the module removal procedure.
JDL
  • 16,098 POSTS
http://postimage.org/image/7y60zgys/
Click on the link. I usually break something trying to work on the dash, your on your own.
