HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Dakota
Fuel System
Fuel Filter
Replace/Remove
SPONSORED LINKS
Fuel Filter
RANGERIDER1863
MEMBER
1995 DODGE DAKOTA
Where is the Fuel Filter?
Monday, October 29th, 2007 AT 10:30 AM
2CARPRO JACK
MECHANIC
The only filter in that truck is the one on the fuel pump inside the fuel tank. This guide will help
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
SPONSORED LINKS
Monday, October 29th, 2007 AT 11:14 AM
ILIKELORA
MEMBER
1 POST
DODGE DAKOTA
Where is the fuel filter in a 1994 dodge dakotaSLT with a 318, 5.2L V8 engine with 170,000 mls?
Tuesday, April 2nd, 2019 AT 6:38 PM (Merged)
SERVICE WRITER
MECHANIC
I don't believe there is an inline filter on that one.
PACKENHAMJ
MEMBER
1 POST
1994 DODGE DAKOTA
I have the haynes repair manual with a diagram of where it should be, but I still can't see it.
MECHANIC
Under vehicle, driver side, below bed area, driver side of fuel tank, mounted on frame rail in fuel line
SPONSORED LINKS
RPTHOMAS
MEMBER
1 POST
1994 DODGE DAKOTA
V8
2WD
AUTOMATIC
Where is the fuel filter located on my 1994 dodge dakota slt with a 5.2 engine?
Tuesday, April 2nd, 2019 AT 6:39 PM (Merged)
MECHANIC
The filter is found under the bed of the vehicle along the left side frame rail.
Image (Click to make bigger)
TINKERBELL_7430
MEMBER
1 POST
1994 DODGE DAKOTA
V8
4WD
Where is the fuel filter for a 1994 dodge dakota 318 motor
MECHANIC
Looking at Mitchell 1 it appears that the filter is part of the pump assembly in the fuel tank.
Mark (mhpautos)
USWALKERS7
MEMBER
1 POST
1994 DODGE DAKOTA
Engine Mechanical problem
1994 Dodge Dakota 6 cyl Two Wheel Drive Automatic
where is the fuel filter located
MECHANIC
Please
login
or
register
to post a reply.
Related Fuel System Fuel Filter Replace/Remove Content
Fuel Filter Location?
Where Is The Fuel Filter Located And How To Change?
Asked by
gt302ho
1 IMAGE
2002
DODGE DAKOTA
Fuel Pump
I Have A 95 Dodge Dakota Slt 318 5.2 L I Drove My Truck All Week And On Fri It Had A 1/4 Tank Of Gass And Then I Park It And Then Sat...
Asked by
shorty18128
1995
DODGE DAKOTA
1995 Dodge Dakota Fuel Pressure
Engine Mechanical Problem 1995 Dodge Dakota 6 Cyl Two Wheel Drive Automatic How To Test A Fuel Pressure Regulator
Asked by
azbozzman
1995
DODGE DAKOTA
1995 Dodge Dakota Gas Problem
Engine Performance Problem 1995 Dodge Dakota 6 Cyl Four Wheel Drive Automatic Almost Two Years Ago My Truck Begin To Slow Down To...
Asked by
hobdey85
1 ANSWER
1995
DODGE DAKOTA
1997 Dodge Dakota Fuel Pressure
Engine Mechanical Problem 1997 Dodge Dakota V8 Four Wheel Drive Automatic Engine Cranks-will Not Turn Over. Checked Fuel Pressure With...
Asked by
mmmccabe123
1997
DODGE DAKOTA
VIEW MORE
SPONSORED LINKS
Replace Fuel Filter Chevrolet S-10
Tune up
Fuel Pump Pressure Test
Online car repair manuals
