Engine turns over, no spark
TYGUY75
  • 1994 DODGE DAKOTA
Six cylinder two wheel drive manual.
I have the SLT model with the 3.9 v6 magnum engine. I bought the truck off a guy who could not get the thing to start. We are getting no spark and I have replaced the spark plugs, plug wires, distributor cap and rotor, ignition coil, and I had the ECU rebuilt, and still no spark.
What is the next thing to look at? Have I skipped an important step? I am pretty well out of ideas, so I am pretty much just checking all my fuses, but so far, they are all still intact. Is there a switch I should check or any fuses/fusible links that are not in the fuse box?
Sunday, August 15th, 2010 AT 3:16 PM
CARADIODOC
  • 33,742 POSTS
Tyguy75. Welcome to the forum. Yes, you missed the most important step. Did you check for fuel pressure? If it is also missing, you have a problem that the two systems have in common.
Start by measuring the voltage on either of the two small terminals on the back of the alternator. You should see full battery voltage on one of them for one second after turning the ignition switch to "run", and again during engine cranking. If it is there for the first second but not during cranking, the automatic shutdown relay is not turning on due to missing pulses from the crankshaft position sensor or camshaft position sensor. The ASD relay also sends power to the fuel pump, alternator field, injectors, coil(s), and oxygen sensor heaters.
Caradiodoc
Sunday, August 15th, 2010 AT 3:31 PM
TYGUY75
Greatly appreciated response Caradiodoc. So what is the correct way to test for fuel pressure? If the problem turns out to be exactly what you have described, what is the correct fix? Do I need a new ASD relay or a new crankshaft position sensor?
Sorry to sound so nooby about this. I am seventeen and constantly working on some project car or another, mostly playing out of Haynes manuals and the internet. I am hoping to start my mechanic apprenticeship next year, but at this point I am still getting comfortable with anything beyond oil changes and spark plugs.
Sunday, August 15th, 2010 AT 10:35 PM
CARADIODOC
  • 33,742 POSTS
Nice to hear about your goals. I taught Engine Rebuilding, Electrical, Brakes, and Suspension and Alignment for nine years and have a lot of notes pages that I produced. Holler if you have other questions or would like copies.
The place to start with this vehicle is the system operation. Manufacturer's service manuals include these sections. They do a much better job than the aftermarket manuals.
When you turn on the ignition switch, the engine computer turns on the automatic shutdown (ASD) relay for one second. That is to insure fuel pressure is up and ready for starting in case the pressure dropped off overnight. You should be able to hear the pump run for that one-second burp. What is more important is what happens next. During engine rotation, cranking or running, pulses of voltage are generated by the camshaft position sensor and the crankshaft position sensor. When the engine computer sees those pulses, it turns the ASD relay on again. Voltage from the relay goes to the fuel pump, alternator field, ignition coil, injectors, and oxygen sensor heaters.
In the case of a crash that ruptures a fuel line, fuel will not spray from the injectors when there is no pressure so the engine stalls. When the engine stalls, there are no pulses from the cam and crank sensors so the computer turns the ASD relay off and that turns off the fuel pump to prevent dumping raw fuel onto the ground. The system is designed to prevent fires and is very effective and reliable.
There are really three circuits. The ignition coil circuit is the one you have been working in. The fuel pump is the second circuit. Both of them give very little trouble. The third circuit consists of those two sensors and causes the most trouble.
One advantage you have is Chrysler has a very user-friendly way of asking the engine computer to tell you what is wrong. Cycle the ignition switch from "off" to "run" to "off" to "run" to "off" to "run" three times within five seconds without cranking the engine. If the engine does crank, even for an instant, turn the switch off, wait a few seconds, then start over. After the third cycle, watch the check engine light. It will be on for a few seconds as a bulb check, then will go off, and after a few more seconds will start to flash out a series of two-digit fault codes. Most vehicles will start with code 12; that is one flash, a short pause, two flashes, then a longer pause before the next code starts. Code 12 just means the ignition switch was turned off recently. Write down the rest of the codes. The last one will be code 55 which just means "end of message". If you think you miscounted, cycle the ignition switch off and back on once and the sequence should repeat. On a few vehicles you will have to cycle the switch three times to view the codes again.
During the 1980's and 1990's Chrysler was very consistent with their codes. You can use almost any service manual for any Chrysler vehicle to find a description for each one. Let me know what you come up with for code numbers and I will look up the descriptions. If we are lucky, one will have to do with one of the two sensors I mentioned.
The camshaft position sensor is in the distributor. The crankshaft position sensor is on the passenger side rear of the engine. I believe it actually sits in the transmission housing. It is a magnetic sensor that reads gaps in a metal ring attached to the flex plate to determine which cylinder is on top dead center. I never replaced a crank sensor on a truck, but on the front-wheel-drive vehicles, the air gap of the sensor is critical. A new sensor from Chrysler's supplier will have a thin cardboard spacer glued on the end to set the gap. Push the new sensor all the way in and tighten the bolt. That spacer will slide off when the engine is started. Some aftermarket sensors have a plastic rib molded onto the end to set the gap. It will partially wear away during engine operation. If that style sensor is removed, the rib must be cut off and a new paper spacer stuck on to reset the gap. The dealer's parts department has the spacers. Again, I do not know if that applies to the trucks, but on the fwd vehicles, if you push the sensor all the way in without a spacer, it will be broken the first time the engine is cranked.
The single most important test is to determine if the ASD relay is being turned on during cranking. You most likely will not be able to hear the fuel pump running so the easiest way is to use an inexpensive digital voltmeter or a test light on any of the points that get their voltage from that relay. The ignition coil is usually fairly easy to reach, and the twelve volt feed wire is typically dark green with an orange stripe. That same wire feeds the field winding in the alternator. It is impossible to tell which terminal is which on the back of the alternator because the two wires disappear into a black plastic block. It does not matter though. When the ASD relay turns on, one of the two small nuts holding that block on will have full battery voltage and the other one will have less, but not zero volts. Both will have zero volts if the ASD relay did not turn on.
A more involved method of determining if the ASD relay is turning on is to remove its cover, then watch the movable contact while a helper cranks the engine. You should see it flip for that first one second, then it should flip again during cranking. If it does flip for that first second but not during cranking, suspect the cam or crank sensor. That is where the diagnostic fault codes will come in handy. Any stored codes will be erased from memory if the battery was disconnected or run dead so you might have to crank the engine for a while for the problem to be detected and the code recorded again.
Another way to read the codes is with a scanner. If you plan on working on cars professionally, I strongly recommend you buy a scanner of your own so you do not have to wait in line to use the shop's equipment. I am driving around right now with my Chrysler DRB2 connected to my minivan. It will do everything necessary while aftermarket scanners never do all the things the manufacturer's stuff will do. The DRB2 works on all Chrysler products from 1983 through 1995 but it requires various plug-in cartridges. I also have the newer DRB3 which works on 1998 through most 2004 or 2005 models. With a plug-in cartridge, it will work on 1994 to 1997 Chrysler's as well as any brand and model of car sold in the U.S. After 1996. A different cartridge lets it work back to the 1983 models.
If you want to invest in an aftermarket scanner, the best one, I have heard, for the money is the Genysis version 3.0. I never used it but I heard it can be updated over the internet. Snap-on has a number of scanners too but everything they sell including updates is expensive. You can find good used equipment from the guys who drive the tool trucks around to the shops. They will trade in stuff from people who are upgrading or leaving the industry. Other times they will know someone who has a scanner they are trying to sell so they can buy a newer one. The common vendors are Mac, Matco, Cornwell, and Snap-on. If you cannot find them in the phone book, stop in at any new car dealership and ask the mechanics when the guys show up. It is usually once a week or once every other week.
If you really want to have fun, I sell the DRB3 at old car show swap meets. You can buy them over the internet right from the manufacturer, (OTC), but the kit is very expensive, around $6,200.00. I get them for less through the parts department of the dealership I used to work for. You can find a good used DRB2 on eBay for less than $200.00 which would be fine for your truck but be sure it comes with the proper cartridge. The last one had a yellow sticker matching the yellow service manuals for 1994. It is an updated version of all the other cartridges that came before it. The cost is reasonable for someone starting out, but the vehicles it covers are disappearing fast.
Both the DRB 2 and DRB3 include an "actuator" test that allows you to run stuff that is controlled by the various computers. In the case of your engine computer, with the press of a button, you can fire the ignition coil to see if it is working, fire the injectors, turn on the radiator fan, tun on the ASD relay, and turn on the fuel pump relay if the vehicle uses one separate from the ASD relay. I have never seen an aftermarket scanner that can do actuator tests, but that could have changed within the past few years.
Caradiodoc
Monday, August 16th, 2010 AT 5:19 AM
MIKE91GA
On my Dodge I found that the hall effect sensor/distributor pickup magnet had a bunch of crud on it. So sometimes it put out a signal which resulted in intermittent engine failure.
Cost $40.00 to replace and has been cranking great since.
Thursday, October 2nd, 2014 AT 8:02 AM
DAVID SPONSEL
Hey just to let know, my 1995 dodge Dakota had same issue with no. Spark, end up being crankshaft sensor. Replaced and now back on the road.
Sunday, February 19th, 2017 AT 4:15 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Hey,
Great addition to this thread! Please feel free to help out on the site whenever it can add information that will help people.
Best, Ken
Wednesday, February 22nd, 2017 AT 2:06 PM
TERRICORDONI
  • 1994 DODGE DAKOTA
V8 four wheel drive automatic.
No spark to the coil. Please help.
Wednesday, February 22nd, 2017 AT 2:07 PM (Merged)
WRENCHTECH
  • 20,757 POSTS
Spark does not go to the coil, it comes from the coil. You have to test for power at one terminal and ground pulse on the other terminal.
TERRICORDONI
There is no power going to the coil at all.
WRENCHTECH
  • 20,757 POSTS
Did you realize that it is only supposed to be powered for the first two seconds of "key on" and then again when the PCM see a tachameter signal from cranking?
WALLEYE CHASER
  • 1994 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 165,000 MILES
Six cylinder two wheel drive manual 165,000 miles.
I am needing help finding out my problem with my truck of no spark. So far I have replaced the coil and the pickup coil, ECM. I have read in the Chilton manual that if there is a fuel system problem that it will shut the system down. Does that pertain to the auto shut down relay? I am open to any suggestions and will to check anything out just need this truck running. Thanks in advance. I will be glad to donate once my problem is resolved.
JDL
  • 16,098 POSTS
Did you check for codes? With the engine cranking, is there any primary voltage to the ignition coil, injectors?
You might try unplugging the heated o2 sensor, then see if spark comes back.
I just wanted to add, the computer needs to see the proper cam and crank signals or it may not ground the asd relay. The ASD relay supplies voltage to the coil--injectors-- heated o2 sensor--whatever else. The hall switches have three wire connectors, ref voltage--ground--signal, you need to check all three circuits, if troubleshooting points you in that direction.
WALLEYE CHASER
There are twelve volts going to and coming out of the coil, I had the pickup coil tested at AutoZone and they told me it was bad so I replace it and still no spark, the o2 sensor is unplugged, have not received any codes yet though. I see a lot of instructions to replace the crankshaft sensor. Also, what is the proper way to check a ASD?
JDL
  • 16,098 POSTS
Is the primary connector at the coil, a two wire connector, that is B+ and ground? Take the connector loose, use an led test light on the two terminals, have somebody crank the engine. Does the lite pulse?
If you have good voltage at the coil and injectors, with the engine cranking, the ASD relay appears to be okay.
You did check for spark at the plugs, correct? Did you take the coil wire loose from the distributor cap, hold the wire close to an engine ground, have helper crank engine, watch for spark to jump? It might be safer on the system to use a spark tester.
LOW DOWN
  • 1994 DODGE DAKOTA
  • 190,000 MILES
My truck with the 3.9 quit running on me and with two exceptions will not restart. I have had no previous problems with this engine. The two exceptions that it did restart it ran normally. It did shut off once the second time I turned it off. The engine just spins over. There is no spark from the coil but I have not yet checked for power to the coil. The on-board diagnostics give me a code 32 and a code 42. I have read every thing from a notorious three into one pigtail corroding to the crank shaft sensor. Are there test I can perform to narrow this down instead of just tossing out cash for unneeded parts?
  • 52,797 POSTS
Hard to do testing without a scan tool to verify crank sensor reading. It is the most common failure for this condition. Try removing the connector and looking for corrosion.
CARADIODOC
  • 33,742 POSTS
Hi guys. Check for voltage at the ignition coil primary "positive" wire, any injector, or either small wire on the back of the alternator. You should see twelve volts there for one second when you turn on the ignition switch and you might hear the fuel pump hum too for that one second. What is important is if that voltage comes back during cranking. If it does not, suspect the crankshaft position sensor just mentioned.
Code 42 is related to something shorted on the line coming from the automatic shutdown (ASD) relay that feeds the ignition coil, fuel pump, and injectors. The clue there would be there is no twelve volts to those items for that first one second when you turn on the ignition switch. That is best tested with a test light. Most digital voltmeters do not respond fast enough for you to see that voltage.
You might try swapping the ASD relay with a different one like it. They do not fail very often but you do not want to overlook something simple.
BZ5
  • 1994 DODGE DAKOTA
Six cylinder two wheel drive automatic.
My truck stalled in the driveway and now will not restart. It is getting fuel and I believe there is no spark. I replaced the cap and rotor. Still nothing. Try the coil next or try something else? The engine turns over but will not fire.
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer.
CHASEYDUDE
I have a 1999 Dodge Dakota v8 5.2 and I am having the same problem no spark. I can hear my fuel pump kick on and my PCM relay and I know my PCM is good because it has already been re-manufactured. I have replaced my coil pack, cam sensor, and my crank shaft sensor but my brother in-law put it on and he is lazy so I am wondering does your crankshaft sensor have to be hooked up a certain way because I have narrowed it back down to this been trying for the last two weeks its has to be the crankshaft sensor.
Friday, July 7th, 2017 AT 2:06 PM
