Yes I did I tried a different computer as well with the other computer I have fuel and spark but still wont run and still no fuel or amp gauges but I has fuel and spark so should run u would think ne ways
Thursday, November 6th, 2025 AT 9:06 AM
KEN L
MASTER CERTIFIED MECHANIC
Yep, if it has fuel and spark with compression it should run, does it make a difference wen you use staring fluid?
Friday, November 7th, 2025 AT 8:55 AM
JUGGALOTUS139
MEMBER
Haven't tried starting fluid cuz u dont have ne
Friday, November 7th, 2025 AT 10:57 PM
JUGGALOTUS139
MEMBER
So I swapped put the computers and now I have fuel and spark but still doesnt run if I spray starting fluid into intake it will fire but still no gauges and still not running
Saturday, November 8th, 2025 AT 3:29 PM
KEN L
When you turn the key on without cranking the engine over can you hear the fuel pump running inside the gas tank? Please go over this video again
You can rent the gauge at the auto parts store for free. Please let us know what happens.
Monday, November 10th, 2025 AT 8:59 AM
JUGGALOTUS139
MEMBER
Gas is good pulled a fuel pump out of a running truck still nothing getting thru the injectors into the cylinders fuel rail has tons of pressure constant can dump gas down the intake and it will runn for a second or two then die something is wrong with injectors they aren't firing or something
Tuesday, November 11th, 2025 AT 2:28 PM
KEN L
Yep, okay, lets unplug the MAP/MAF sensor and try it again, if the computer does not see the vacuum or air flow it will disable the fuel injectors from firing, here is a guide to help confirm the injector pulse failure,
