1996 Chrysler Sebring
BIGMIKE5025
  • 1996 CHRYSLER SEBRING
Engine Performance problem
1996 Chrysler Sebring 6 cyl Front Wheel Drive Automatic
CAR IDELS ROUGH AFTER IT WORMS UP
Do you
have the same problem?
Friday, September 3rd, 2010 AT 11:40 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Saturday, September 4th, 2010 AT 4:48 AM
Recommended Guides
