Not cranking over - starter problems
  • 108,269 POSTS
Are you getting spark and fuel to the engine? Also, have you determined where the coolant is leaking? Could it be a headgasket?
Friday, January 3rd, 2020 AT 9:59 AM (Merged)
2CP-ARCHIVES
  • 4,542 POSTS
  • 2002 CHRYSLER PT CRUISER
Car ran hot now wont crank back. It turs over just wont catch fire.
WRENCHTECH
  • 20,757 POSTS
You have likely done some serious internal engine damage. You will have to do some pressure testing sand compression tests but you are likely looking at a new motor.
You absolutely cannot overheat today's engines.
2CP-ARCHIVES
  • 4,542 POSTS
  • 100,843 MILES
My 2002 PT cruiser broke down a week ago. It was driving fine and all of a sudden the check engine oil light came on and the car steering wheel began to lock up and shut down. I just had an oil change and other maintenance done to the car that same month. What could be wrong with my car? I need to know what part or parts are needed to fix the car. The car will not turn on. I can hear it trying to turn when I turn the switch on, but it still will not crank.
The mechanic that gave me the run around had me going back and forth buying parts for the car that does not fix the car. First it was supposedly the crank sensor. That didn't work. Then it was supposedly the coil package. That didn't do the trick either. Then the last time I spoke to this guy he said he would go back and get the crank sensor again to put on the car. This means I will have a new crank sensor and the new coil package. This is what he thinks would get the car up and running again. He got half way started with getting the coil package. After that he bailed on me without warning and lied about coming back to fix the car. Now I have a car that has been broken down for two weeks with no other mechanic to come and finish the job.
CARADIODOC
  • 33,752 POSTS
Very few professionals have the time to run to your house. Just like with doctors, it is impractical to haul around all the specialized equipment and tools they need. Tow the car to a repair shop and let them diagnose the problem correctly and get it running. By now you've figured out the most costly and least effective way to diagnose a problem is by throwing random parts at it.
If the red "Oil" light turned on, did that happen while you were driving or after the engine stalled? It will come on when the engine stops running. If the yellow "Check Engine" light turned on while you were driving, the Engine Computer detected a problem and set a diagnostic fault code to indicate the circuit or system that needs further diagnosis. It's important to understand that fault codes never say to replace parts. Even if the Check Engine light didn't turn on, there can still be fault codes related to the problem. You can read them yourself very easily on Chrysler products. Cycle the ignition switch three times from "off" to "run" within five seconds without cranking the engine, then watch the code numbers show up in the odometer display.
HOWTODRIVESAFE
  • 2001 CHRYSLER PT CRUISER
  • 161 MILES
I have replaced battery battery cable and the starter. The car will not spin over with the key. Will not crank everything inside is working as should such as lights radio etc. I am a general mechanic I am looking for a Chrysler specialist.
Friday, January 3rd, 2020 AT 10:01 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
Is the security light on solid or flashing?If not we need to follow this guide to see if the starter is okay. It sounds like the starter relay could be bad.
SATURNTECH9
  • 30,870 POSTS
If the security light isnt on then you should have power to the yellow wire coming out of the ignition switch with the key in the start position. Also constant power to the red wire at the ignition switch.
HOWTODRIVESAFE
Ok, let me see if I can get this straight. There's two red lights in the dash one is in center where tech is and there's another one with picture of little car. BEFORE I replaced starter one in the tach was solid. It now comes on for a second then goes out. The one with little car blinks for about 10 seconds goes out. I hope this makes sense.
SATURNTECH9
  • 30,870 POSTS
As long as the lights go out and stay out were good. Go ahaed and check those wires.
HOWTODRIVESAFE
We checked the power wires your talking about I have no power to these wires.
SATURNTECH9
  • 30,870 POSTS
The red wire to the ignition goes back to the number 1 thirty amp fuse in the under hood fuse box like it shows in the wire diagram I posted. So see if there is power to both sides of that fuse.
HOWTODRIVESAFE
I was wrong red is hot yellow is not. I installed a new ignition switch that fixed it
SATURNTECH9
  • 30,870 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
